brake master cylinder cover / housing for Narrow body
Hi there,
after a quick run yesterday, i feel heat from engine.
i remove the bonnet and the housing is missing (don t know if it s the correct way of describing parts)
could I find one S/H ?
thanks for your help
Oh my, that wont help with the heat or fumes. You will need  to make one from alloy, start by using cardboard to create a pattern then scribe onto alloy and cut out. Rivit on as normal. Here is mine - same car
thanks for your reply, that was also an option :)
Its had one on there once, you can see the holes it left.
thought it was available as part of the kit :)
It was once, but even when the factory was still going they had little stock left for narrow cars, from now on you will have to make stuff like this yourself 👍
I have a few new fibreglass covers as were fitted to the narrow bodywork cars . New un-drilled etc in black. Pm me if your still wanting one please
pm :)
  • 4 months later...
any on the market before i make one ?
