Hi spec front hubs.
Aluminium front hubs. Brought off here a while a go but these in need of some work to make them usable.
Brand new but have poorly machined bearing surfaces meaning that disk run out is bad. (Unfortunately common for Hispec 😔)
Bearing races need to be turned out and sleeved or run an oversize bearing to make them good.
Have studs fitted.
One hole for the disk mount also had a helicoil which isn't seated correctly and would need fixing.
Anyone with a lathe or willing to take to a machine shop could get these sorted and would be cheap hubs?
£50
Can give to a courier if you arrange.
Anyone before the dreaded eBay...
