Standard SEiW dampers - front and rear.
Standard dampers for sale due to upgrade(?) To widetrack and protech dampers..
Perfect working order. I estimate these have done around 10k miles.
Perfect working order. Adjusters all free and we're working perfect before being removed. Bushing and bump stops all in good condition.
I'm all honesty these were working as good as the brand new protechs (which were revalved and dyno'ed before fitting) which replaced them. Was definalty no step improvement.
Only benefit from the protechs is weight and the adjustment is finer. That's it.
I think these are GAZ dampers. Part numbers below, but they do say B12 on them so maybe Bilstein?
They are steel bodied.
These ran with the standard 300lbs front and 175lbs rear springs on a 575kg car.
Rears GPA 1106 B12 LQ5
11inch closed 14.5inch open.
Fronts GPA 1105 B12 KO7
10inch closed 12.5 open.
£125
Happy to give to a courier if you arrange
Anyone before the dreaded eBay...
