mikey p Posted August 11, 2022 Posted August 11, 2022 Custom made 4-1 collector and angled link pipe. Slip joints to accept 1.75inch primaries with up to 40mm ish insertion. Total length 20.5inch. 2.5inch OD at exit. True merge collector which is best for performance. Had a lambda boss. This fitted a manifold which was designed to exit in the standard position for a type 9 chassis with driverside exit and tucked the exhaust silencer (wunoff) up against the body. £60 Happy to give to a courier if you arrange.
