Do cycle wings need some sort of edging strip to get through SVA or was that a knightmare i had last night?
Also while Im posting, I need an alternator by friday for a VX20XE, is there any others that I can pick up from my scrappies and fit?
I think standard glassfibre westfield cycle wings are OK as they have a return edge.
I have carbon effect (aka plastic) wings and needed to fit rubber edging, fixed underneath with electrical tape and removed after SVA.  It all depends on whether the edge has radius less than 3mm.
HTH
Leon
You do not need an alternator for the SVA My car passed Jan this year less an alternator. Charged battery before test and completed test with no problems.
Hmmm do you think I'd be able to drive 80 miles there, do the test and drive 80 miles back though??
An injected car will flatten the battery quite quick as well :(
Cheers Matt, didnt think id make the journey.  So can I use another alternator or is the VX Astra/Cavalier the only one that fits?
You should find an alternator from a lesser Vauxhall model would fit. ;)
Sorry if I've missed the point here but can you drive an un-registered un-SVA/MOT'd  car on the road to the SVA centre??
As long as it's insured.
Yes, you can drive it to the SVA centre.   Check with your insurers though, some companies cease cover the instant it fails, so the return journey won't necessarily be covered.
Also, make sure you have all the documentation from the SVA centre handy.
You can also drive it to the vehicle registration centre as long as you have a bona fide appointment for inspection there too.
  • 2 weeks later...
past SVA today and I had to put edging  (used 5mm went on easily) around both sides and the rear of my cycle wings. The inspector said that there is only a return on the front, which is acceptable. good luck
orange t
Had my SVA on thursday, failed, but not on the cycle wings, they were fine, guess it varies from centre to centre.
Sorry to hear that matey. what did it fail on??
Stuart
SCRATCH THAT QUESTION - JUST SEEN THE ENTRIES IN TECH FORUM.
I used a bit of wet n dry on the front and rear arches and had no problem with the SVA inspector. Wet n dry gives a better finish than edging tape.
