Scuff Protector
Noticed around the drivers and passenger side where the doors rub on the bodywork scuffs. Anyone got pictures or ideas I can use to reduce this?
I expect you can reduce the scratches by careful sanding or cutting back with an appropriate compound provided they are not too deep. For protecting the body where the bottom edges of the sidescreens are pulled in against the GRP I've stuck on a strip of Luxshield clear vinyl on either side,  from Amazon.
That sounds great. I'm having the bodywork looked at in September but will order what you recommended as looks good for the job. Thanks.
Helicopter blade tape. Is excellent stuff for just such issues. I've got it on various parts of my bodywork.
OK cool will have a look.
+1 For helicopter tape.
+2 for helicopter tape
3M's blade tape. If it can stay on a rotating blade, it's good for a car and is a bit thicker than some other clear films.
