Westfield SuperTec - 628BHP per Tonne - REDUCED TO £25,000 - out accelerates a £175k Ferrari 458!!
For Sale – Westfield SuperTec - 628BHP per Tonne - £27,777.
Due to an unexpected opportunity I offer for sale a well known & very special Westfield (Nessie). Whilst owning the car it has been developed further preparing the car for use on public roads (improved cooling, installation of larger fuel tank and compressor to operate the Quaife sequential paddle change & remapped by NMS 330BHP). It now has passed an MOT (daylight running)
History
The car was originally built to a very high standard by Paul Aspden, the founder of Playskool Motorsport in circa 1999/2000. It was also owned by WSCC legends, Steve Davies and latterly Mike Allard (The Duck). Mike ran the car successfully in the Speed Series for a time before Richard Kerr purchased her in around 2005/6. It ran a high performance Vauxhall XE with around 235hp and was mated to a Quaife Syncro box.
Initial development produced more power (262 BHP), a Quaife Dog Box. Resulting in winning the Speed Series outright in ’09.
The biggest developments came in 2012 when the journey to 357hp began. Two years spare time lost in the workshop, developing parts, engineering them, trial fitting, many late nights, a whole load of goodwill and a substantial amount of money later, the SuperTec was born! Not for the faint hearted, this car will do 0 – 60 in 2.5 seconds and will get you to 100mph in under 5.7 seconds, it really is that quick!
Spec as follows:
Engine
Freshly rebuilt in 2020, mapped & run in by Troy at NMS. Covered less than 500 miles.
2.0 Supercharged Duratec producing 357bhp on NMS Rollers (525kg car) - car detuned to 330BHP by Troy 2021.
Carillo Steel Rods
Supertech Pistons – Brand New for 2020
Newman Cams
Cosworth Steel Crank
Uprated Valves
Uprated Springs
Rotrex C30-94 Supercharger on Custom lightweight mount
750cc Injectors
Custom 4-2-1 Exhaust with 50mm headers
Titan Dry Sump
Titan Oil Pump
SBD Dry Sump Tank
All Newly made Braided oil lines with matt black couplings
Small Lightweight Denso Alternator on custom Bracketry
TTV 1 Piece Custom Crack pulley, keyed to suit crank
All Custom engine Mounts – engine solidly mounted
Bespoke Motorsport Wiring Loom
Custom PCCB Delete plate
Throttle Bodies
Bespoke Polycarbonate Plenum
Bespoke Aluminium Intercooler
Upgraded Golf Radiator
Lightweight Plumbing with Co-ordinating Blue silicon hoses, (Water and Air)
Davies Craig Electric Water Pump and controller
DTA S100 ECU Controlling Engine and Sequential Gearbox
Traction Control – wet and dry with interchangeable dial switch settings,
Launch control
20 Litre Foam filled Fuel Tank with internal primary pump
Fuel swirl Pot
High and Low Pressure Fuel Pumps
7” Superclutch
SBD Lightened Flywheel
Always run on Millers Nano Grade Motorsport Oil
Brand New Magnecor leads and plugs
It's also worth noting that the car is only running 0.7 bar of boost, there is a lot more power to unleash with fairly minimal effort or expense .
Drive Train
Quaife 60G Sequential Gearbox on paddles, flat shift controlled via ECU, clutch off the line only!
Pneumatically controlled with onboard bottle
Box Fully rebuilt 2017 – covered less than 100 miles since
Rear Flange Modification Completed
Carbon bespoke paddles mounted on Racetec Steering Wheel
Lightened and balanced Bailey Morris Propshaft
Quaife ATB Differential built into refreshed Sierra Casing
Titan Bellhousing
Steering and Suspension
Titan lightweight bespoke steering Rack (new 2016)
Siltec Lightweight Alloy Uprights
Siltec Widetrack Wishbones
Protech Double Adjustable shocks Front and Rear
Eibach Springs 400lbs front 250lbs rear
Polybushed Rear Wishbones
Playskool Front Anti Roll Bar
Playskool Rear Anti Roll Bar
Worx Bell Racing Qiuck Release Steering Wheel Boss
Wireless Removal of Wheel
Bodywork and Chassis
Car 525KG
Lightweight Westfield ZK Bodywork
Mickmade Carbon Side Panels
Mickmade Carbon Nose
All Carbon Interior Panels
Carbon Tillet Seat
Playskool 3” Harnesses, FIA Approved and in date
Part Honeycomb Composite removable Floor
Westfield Lightweight Chassis
Caged Homoligated Cage
V8 Bonnet
Carbon Aeroscreen
Carbon Cycle Wings
Carbon Boot Cover
Carbon dash
AIM MXS Strada Programmable Dash, with GPS and Logging (New 2018)
Wheels/Tyres
1 Set Force wheels mounted with new Toyo  888 tyres 10” front 12” rear
Car is MSA log Booked.
Car MOTd (daylight running)
This is a serious car with a huge amount of development completed (time and money). Price £27,777 - Caterham 620R performance at a fraction of the price.
Please call or email for further information - 07952 513623
Cheers Simon
(Photos to follow).
Nessie in action
The video clip doesn't seem to work for me. Then again, I remember the car well and can vouch for just how incredibly quick this car was
Photos of znessie
A6DA18A2-747B-45DB-9CE2-DD4DF98918FC.thumb.jpeg.92600750cf113ba51794d857699c381a.jpeg106B986C-9516-4413-A631-BF343B002906.thumb.jpeg.e77bdc0933f3b968fadc71df60d2622b.jpegA6DA18A2-747B-45DB-9CE2-DD4DF98918FC.thumb.jpeg.92600750cf113ba51794d857699c381a.jpegA6DA18A2-747B-45DB-9CE2-DD4DF98918FC.thumb.jpeg.92600750cf113ba51794d857699c381a.jpegA6DA18A2-747B-45DB-9CE2-DD4DF98918FC.thumb.jpeg.92600750cf113ba51794d857699c381a.jpeg106B986C-9516-4413-A631-BF343B002906.thumb.jpeg.e77bdc0933f3b968fadc71df60d2622b.jpeg0C9E725A-E8D8-4DB3-B722-94689F19837B.thumb.jpeg.31ea7e12307e405bb86e9a461b16b0a3.jpeg0C9E725A-E8D8-4DB3-B722-94689F19837B.thumb.jpeg.31ea7e12307e405bb86e9a461b16b0a3.jpeg599B2191-7E20-4073-9371-CEE20FF8F71A.thumb.jpeg.a2a997eb00bef263f2b8c8d4aaf7c164.jpeg2272B2AD-2247-4269-8B3B-1E64E5D12D50.thumb.jpeg.faf8c11d6845d07b810624bb5ca10987.jpeg
That's a serious piece of kit 👌😂
  • 1 month later...
I have a dilemma - my new project is at the stage where it needs to come home so I need the garage space. I am a BIG believer that cars need to be driven & enjoyed rather than put into store. I have therefore decided to reduce the price to £25,000.
Another option would be to break the car up & sell the components but given the time, money & ingenuity Richard and Luke put into developing the car this option would be a very last resort. Any serious prospective purchases please contact me - If Carlsberg built a Westfield I'm sure this would probably be the car. Its a great feeling to out accelerate a Ferrari 458 costing £175k!!
  • Rossins changed the title to Westfield SuperTec - 628BHP per Tonne - REDUCED TO £25,000 - out accelerates a £175k Ferrari 458!!
  • 3 weeks later...
Having driven the car last week I have decided to keep it & get out on some trackdays.
  • Like 6
  • 2 years later...
On 02/07/2022 at 04:32, Rossins said:
Nessie in action
No action there I'm afraid. Video link broken?
  • 2 weeks later...
Deposit taken
