Megablade, Completely rebuilt in the last 12 months
Westfield MegaBlade in Red
Originally factory built in 1999, with lightweight BEC chassis, and then nut and bolt re-built in 2021-22, including strengthening of diff area, new powder coated flat floor, and sides, full Westfield FIA caged cage, with welded in mounts in both front and side area’s, reverse box removed but can be bolted straight back in, in less than a hour.
For its age probably one of the best you’re going to see.
The badge on it says "1000rr, but its not, put on by the previous owner 🙄
Westfield Race seats
Carbon dash with new push button billet switches, key ignition and push button start
Carbon effect rear light clusters and arch guards
DigiDash display, speed/RPM/shift lights/temp/Gear position etc
Race tech Quick release steering wheel
OMP flat bottom suede steering wheel
Freshly serviced, Honda 919 Fireblade engine, dynoJet kit upgraded clutch and Barnett springs, alloy catch tank
Cerakote manifold and Cam cover
Nitron shocks all round
FIA full cage
Quick Rack with alloy steering mount
Limited slip differential
Hi Spec 4 pot brakes, mintex pads, Drilled disc's
Front and rear anti roll bars
AB performance force ducted nosecone
Race gel battery
Race safety 4 point harnesses
Carbon “Micron” silencer
Carbon NV cycle wings
Carbon NV sill guards
Carbon boot cover
Carbon race tech mirrors
LED front and rear lights
Team Dynamics black gloss wheels, shod with Toyo R888R rubber
£13000
Westfield reverse gearbox/gear linkage available to the purchaser, by separate negotiation.
Full build & ownership folder with loads of history, only selling because I've just bought a MegaBusa, and I can't afford both 🤯
 I'm out of the country until 03/07, but wanted to get it out there, so replies may be delayed.
ADBF5C91-1153-4A31-AF73-46E0AE2398B2.thumb.jpeg.522f1fc4213158150c7490870b3958e7.jpegC4B530CC-18CE-4052-BCA6-A1BECA0EB8BE.thumb.jpeg.4f9356bc1dc79f388c482645b1b9db3e.jpegCCE7FCE4-8615-4643-8ADD-B08C8B9ACC53.thumb.jpeg.b68f95b30268e8c7858a6f178af45474.jpeg7A7DF36F-1119-43E6-9F95-42378C82EE3C.thumb.jpeg.3d9a6fc3649025ab4a0f875ee0b6fe2a.jpeg0E473CEA-C05A-4D04-848C-6A6DEB95473D.thumb.jpeg.3655c57801329125fdfd7be6355785da.jpeg5CBAFB7C-849A-4F16-94BF-CA88D3384B6F.thumb.jpeg.5dd877c22f554123fe674deb1bdd394e.jpegD26C4480-5914-4855-AA62-54A2483E5B2E.thumb.jpeg.833e5bf3051d80e9fe6b01b2502d7fc5.jpeg539A6F17-3B0D-40E4-8A74-BFF4FF7C688E.thumb.jpeg.b838f1c2411c7f043f28faaa110d7526.jpeg9DC4AEE9-CC19-44B2-ACE6-BC8A45B4CE6B.thumb.jpeg.2aafc53b6ff6e92d8d0d4d9907d0a07b.jpegAA52D31F-416C-41A1-8063-29143E98A1C5.thumb.jpeg.c208d889c4295d4371d983fba0b40218.jpeg0566BD7F-2690-4D2F-838A-EBBEB2A4398F.thumb.jpeg.92c5e97574269e316e09aefd58376a1d.jpeg3B82533D-E291-434B-8987-277218CA1E78.thumb.jpeg.62da52b1e7303e9c9ddd068da817007b.jpegF98373EC-109C-4824-B5B2-0A92038BF6C3.thumb.jpeg.54574d845d7b930c5b7abd2be87ebf40.jpeg052D4C0D-1D11-4248-BDB8-12CA8F9BB142.thumb.jpeg.4ab623e806ff6913ed462421cbfe0adb.jpeg994FA8A1-5238-49C9-A3A4-4B5AD5A0A253.thumb.jpeg.c71217e426696ae25d2ceeef52ff7fec.jpeg
  • 2 weeks later...
Now Sold, and off to live in Newquay, now to start on the MegaBusa, perhaps I'll just enjoy it for the Summer, then do the work ?
Yeah deffo best idea👍
