[NOW SOLD] Dashboard Toggle Switches - (Horn; Indicators; Mainbeam)
And finally (as they say) I have three toggle switches also surplus to requirements following my dash upgrade.
They are:
  • off/(on) - Horn;
  • on/off/on - Indicators;
  • On/off - Main beam.
They are sold as seen in the picture below (without the black self adhesive dashboard decals or anything else on my work bench!)):
The kit was finished in 2020/21 and had done c. 2500 miles when I took them out.
You can have them for £12 - you can collect or I can post at approx. +£4.
DAVID
Hi David
Do you still have the indicator toggle switch, and if so what do you want for it
regards
Derek
Hi David, do you know how many times the main beam switch has been toggled?
I don't think it was many, he never goes out at night...☺️
@The artist formerly known as Rush Motorsport- Richard’s right. It’s not my daily driver and it doesn’t go out in heavy wet or dark! 1100 miles when I bought the car, roughly 2500 when I took the mag toggle out and I won’t have used it 30 times. D
I’m not sure what I meant by “mag”! Don’t read anything into it. 🤪
I don't drive mine at night either, only happened once in the last 6 or 7 years. Not because I don't want to, but I have no need to go out at night currently. As for rain, well I have set off with it raining, not a lot you can do when you live in the UK, but the soft top does a reasonable job of keeping the water out, but it does leak if the wind is in the wrong direction :marto:.
  • CherryTreeFW changed the title to [NOW SOLD] Dashboard Toggle Switches - (Horn; Indicators; Mainbeam)
