Westfield seiw
Almost everything on this car has been upgraded or replaced in the last 4 years, apart from chassis and body work
Westfield sei 1991 racing Green.
Engine,  vauxhall red top , totally rebuilt last year, spec is coscast head, fully reconditioned only had one light skim, standard valves with bronze k line valve guides, Piper double valve springs anderson race engines spec, turbo sport solid lifters, qed shims, Piper ultimate road cams mechanical, turbo sport adjustable cam pullys, sbd cam blank,  block fully cleaned and decked bored to 87mm honed and then plateau honed, early bottom end crank fully balanced not been ground, acl race bearings big end and mains, maxpeeding rods, accrilite race top pistons,  compression ratio 11.6 to 1 , sbd sump, sbd taper throttle body’s , white giant injectors, sbd engine loom and mbe 956e ecu, sbd design headers made by btb, Simpsons 2 to 1 pipe with Simpsons 7inch can, 201 bhp at the wheels rolling road at daytuner Harrogate.
Transmission,  type 9
Track sport type 9 semi helical rocket box supplied by Steve perks made by first motion transmission total transforms a westfield, sbd Bell housing, new prop North West propshafts,  reconditioned sierra 7 inch diff this winter with 23 degrees quaife atb all new, fitted in place of westfield escort diff, bespoke drive shafts made from 300m steel by djm Nottingham with tripode inner and outer joints, rear discs brake conversion with golf calipers,
Fuel.
Westfield ally tank with sump, fully replaced fuel lines in stainless steel ptfe with areo fittings walbro pump two sytec bullet filters, fuel pressure regulator,
Interior ,  jk seats with heated pads fully trimmed Interior carbon dash, all new switches,  race technology dash, kit car electronics steering wheel buttons, removable steering wheel,  leather steering wheel, inovate wide band afr connected to dash, carbon dash, 4 point harness,
Steering.
Escort mk2 rack with quaife internals, bespoke Steering column with go race quick release,
Westfield wide track front wishbone, protect shox all round supplied by Pro comp vavled for a westfield, team dynamic Pro race 2 wheel with mew 888 rubber, carbon front wheel arches,
Brakes ,  ap racing dual master cylinder the one every one wants, m16 front calipers with green stuff pads ferodo ds2500 spairs golf rear calipers braided hose front to rear hard line to front,
Lights  front led with drl all working as production cars work, rear bespoke light pod with led lights auidi style indicators,  led reverse and fog.
Weather gear,  doors and soft bits roof.
The bad bits the body work let’s it down it would be on my list of things to do next if I was keeping it but it’s a real head turner going down the road, I have totally transformed this car over the last 4 years its a proper ultimate road or track tool , I’ve probably missed loads of stuff,
£13995
20200719_095235.thumb.jpg.25d0f7cad9897449f61326a34df0bc34.jpg20200530_082433.jpg.0862e650144357fb9eeed4d62dcc2cd4.jpg20200530_082256.thumb.jpg.e90c4aa0cda4268110fe8217e939fc8f.jpg20201024_125716.thumb.jpg.c81f5fe8e58f186a49f2bb1d5da240c2.jpg20201022_161104.thumb.jpg.0295f247a822d90f941521a9d82d7f1e.jpg20200201_121335.thumb.jpg.56a499c9523c85f3462ca11fa4be56be.jpg20200201_121327.thumb.jpg.15b3d0286b4ba8377f4c2adfffdcac1f.jpg20200129_191548.thumb.jpg.0c43772824b9f269955ce56e917dbca9.jpg20220122_110138.thumb.jpg.6882d5780009bfd896050b9d24de7434.jpg
20210220_171541.thumb.jpg.2ef84716bff4670b6c71b41d8e20234a.jpg20201024_080752.thumb.jpg.d928358531c4d75e6b1eb6117a91c88e.jpg20201017_133130.thumb.jpg.71818d61d44d751a5e2b7e8d53b82494.jpg20201022_134128.thumb.jpg.b4448566780869afaa943c0b295df13c.jpg20201017_154007.thumb.jpg.4e101afe3f199ad67ee782f503afd457.jpg20200206_174829.thumb.jpg.bc18e018ba2794297a4577d3f8217162.jpg20200206_194421.thumb.jpg.4d78c9a5514597a7e398c9c85e1ed53d.jpg20200107_180200.thumb.jpg.037c125a8e20e5ed7d74061b5db51e66.jpg20200110_185254.thumb.jpg.f6f471a7b56651d6b9f73f691a931682.jpg20191018_185139.thumb.jpg.2ab75822101372f1cc149b35bea453e1.jpg
20201001_175814.thumb.jpg.cef4e591cafb57558e24a4222378ace4.jpg20201010_103636.thumb.jpg.83c9f9f70189587b8a8cb5f20e134d91.jpg854143563_TonyWiddupWestfield2_0XE.png.0b781ac45d0f5ce8e68be647b7a6131d.png20211204_125734.thumb.jpg.b4eb63471c15c5703ad1d301759f0647.jpg20211204_134234.thumb.jpg.f9507052e87c05fcbf8c6358bb17eb5b.jpg20211230_142346.thumb.jpg.844aaaa35b2ba9c08e9066fb241a601b.jpg16549791181988516248917900943154.thumb.jpg.e7723b076e5b784ead84e1cc8dc34656.jpg20171208_204918.thumb.jpg.36dea40fb8d136989764c01edd4d2b9b.jpg
Walk round video this morning
Blat last week
  • wizzer changed the title to Westfield seiw red top
Couple of videos from rolling road, the sound was unreal 👌 201bhp at the wheels under 600kg s2000 eater 😉
Good result 👍
Were you wincing behind the camera 🤣
Just now, Steve (sdh2903) said:
Good result 👍
That day was amazing to put that engine together all the effort and prep to get proper power ,what a feeling 😉
What a stunning car with an amazing spec....I've gone the same way on the dash with the Dash 2 and the kit car electronics freewheel buttons, and find them to be one of the best mods I've ever made.
Best of luck with the sale...someone is going to get one hell of a car.
Heated seats - well really!!
GLWTS
  • Haha 1
I have been out on many runs out with this car (and its owner) and it is one hell of a car.
good luck Tony i hope it stays in the area though.
The attention to detail that's gone into this car is second to none.
The engine has been built to the highest standards and the engineering skill that's gone into the diff/driveshaft set up is in itself worth a trip to see the car.
You won't be disappointed.
Just added a little video 😃
900 views and no takers, I know what your all thinking oh no the mighty xe red top its got to much power defo to much torque, but trust me you'll be fine, 😁
  • Haha 1
You will be sad to see her go I’m sure. Reminds me of my first westie, same colour. You’re westie looks fab. Good luck with sale
Andy
Andy
Just got back home been out with lancs lot up to jubilee Tower and then Glasson Dock,
20220615_194533.thumb.jpg.efb2c6eb5302fa4dcf800ac68bb7f45d.jpg20220615_210045.thumb.jpg.4e8130f4e08064752771dec114a6322c.jpg20220615_210058.thumb.jpg.6ade22d8e1540eb046d65a3de2fc9203.jpg
Defo be sad when it goes, but whoever buys it ,I kid you not its an absolute missile.
