Pete75 Posted May 28, 2022 Posted May 28, 2022 (edited) Hi guys, a friend asked me to start a search for a widebody chassis, Zetec version in excellent condition. Anyone? BR, Peter Edited May 29, 2022 by Pete75 frame replaced through chassis ;-)
Mark (smokey mow) Posted May 28, 2022 Posted May 28, 2022 To help with your search ZK refers to a style of bodywork not the chassis. The widebody chassis frames are the same regardless of whether you choose to fit ZK bodywork or FW bodywork. likewise the chassis were designed to accommodate several different engine options, typically only the engine mounts would be different but these just bolt in. the major differences to be aware of are live axle rear suspension vs independent rear and the different gearbox tunnel widths. The narrowest gearbox tunnel is typically referred to as the type9 and as you’ve guessed was designed for the Ford type9 gearbox, these were typically on early cars. The wider MT75 tunnel will take the Ford MT75 gearboxes and various others. There are also other variations for V8’s and Honda S2000 etc but all should be suitable for a Zetec install. 1
Pete75 Posted July 30, 2022 Author Posted July 30, 2022 He has found one but is still looking for others. Would you have one to offer?
Rednop1 Posted July 30, 2022 Posted July 30, 2022 How many does your friend need and if he needs more than one is he a dealer? And maybe your friend would like to become a member??? He will find the wscc membership excellent value
Paul Hurdsfield - Joint Manchester AO Posted July 30, 2022 Posted July 30, 2022 Isn't Lake Constance in Germany? There are a few members in Germany.
Pete75 Posted July 30, 2022 Author Posted July 30, 2022 2 hours ago, Rednop1 said: How many does your friend need and if he needs more than one is he a dealer? And maybe your friend would like to become a member??? He will find the wscc membership excellent value No, he's not a dealer but an ambitious tinkerer
Pete75 Posted July 30, 2022 Author Posted July 30, 2022 47 minutes ago, Paul Hurdsfield - Joint Manchester AO said: Isn't Lake Constance in Germany? There are a few members in Germany. Lake Constance is in Germany, Austria and Switzerland In AT and GER it's easy to find parts for Caterham but hard to find parts for Westfield.
Pixie Posted August 3, 2022 Posted August 3, 2022 On 30/07/2022 at 15:54, Pete75 said: He has found one but is still looking for others. Would you have one to offer? Hi, I have an SDV stage one kit, not yet started, unlikely to complete for many issues.
