Stu Faulkner Posted May 14, 2022 Posted May 14, 2022 As in the title Does anyone have a spare MX5 MK2 1.8 non VVT engine spare that they are willing to sell?
Dommo Posted May 14, 2022 Posted May 14, 2022 If you're not in a rush I'll be pulling mine from the MX-5 but it's likely to be later in the summer. Unfortunately I've not got the space to do it just yet. Of potentially less use, but I'll note it anyway, I've got a Mk1 engine sat doing nothing, a Mk2.5 engine that I was going to keep the head and sump from, and a mk2.5 block (no crank/pistons etc) and a mk2.5 head which I've just remembered. Basically everything you don't want is lying around now and what you do want is stuck in a car 1
Stu Faulkner Posted May 14, 2022 Author Posted May 14, 2022 2 hours ago, Dommo said: If you're not in a rush I'll be pulling mine from the MX-5 but it's likely to be later in the summer. Unfortunately I've not got the space to do it just yet. Of potentially less use, but I'll note it anyway, I've got a Mk1 engine sat doing nothing, a Mk2.5 engine that I was going to keep the head and sump from, and a mk2.5 block (no crank/pistons etc) and a mk2.5 head which I've just remembered. Basically everything you don't want is lying around now and what you do want is stuck in a car I’m not in a rush, I’ll give you a shout later in the year if nothing pops up.
TAFKARM Posted May 14, 2022 Posted May 14, 2022 Is it for a build? Ive got one that has possible head gasket failure and needs a crank pulley. You can have it very cheap, I keep stubbing my toe on it.
Stu Faulkner Posted May 15, 2022 Author Posted May 15, 2022 7 hours ago, New display name REQUIRED said: Is it for a build? Ive got one that has possible head gasket failure and needs a crank pulley. You can have it very cheap, I keep stubbing my toe on it. It’s for a backup engine that I’m planning on rebuilding.
Trevor Little (Trevturtle) Posted May 15, 2022 Posted May 15, 2022 Try prestige spares (near Rutland Water) on Facebook.. they are cheap and typically break 6 to 8 mx5s a week.
Stu Faulkner Posted May 15, 2022 Author Posted May 15, 2022 1 hour ago, Trevor Little (Trevturtle) said: Try prestige spares (near Rutland Water) on Facebook.. they are cheap and typically break 6 to 8 mx5s a week. Cheers Trev
