Brake upgrade what are they worth ?
Please more if this is in the wrong place
I intend on placing these parts in the for sale section but don't know how much I should be asking so any suggestions are welcome and I will then put up for sale with prices.
Some of these parts were an upgrade option on my Sport 250, the front disc's and caliper mounting bracket has been machined to allow 13" split rims to fit over them.
Item No
1, Aluminium front hubs & vented discs including bearings and aluminum dust covers.
2, Front calipers with Ferodo pads which have a minimum of 15.8mm.
3 Rear discs.
4, Rear caliipers with Westfield pads which have a minimum of 14.2mm.
5, Handbrake and cables.
6, AP Racing bias valve.
7, Master cylinder.
8, Pagid race pads to suit both front and rear calipers, minimum of 14.7mm front and 13.5mm rear.
9, Caliper hoses.
10, Goodridge Speed Bleed easy bleed caliper nipples for both fron and rear, these have a one way valve in the so bleeding brakes becomes a one person operation.
It's just going to end up a for sale thread, so I've moved it there.
  • Thanks 2
Message sent re the master cylinder
Interested in the rear calipers
  • Smudge62 changed the title to Brake upgrade what are they worth ?
Hi
What diameter discs are the front calipers designed to fit.
Disc diameter is 275mm originally they were 278mm but I had 3mm machined off and reduced the caliper mount to allow a 13" split rim to fit over them.
Ok, thanks for the additional info. ideally I was just after some calipers to fit with some new vented, grooved discs I already have which are the same as yours but un machined. so would probably need to keep your discs, hubs and calipers together. How many miles have they all done?
Less than 1500
Out of interest what were the front discs originally for ?
