Kit widebody bodywork
Damaged kit bodywork from a wide .. not the tidiest but with flared side panels it could be of use..
£200 collected from Leeds.
I have the scuttle,  bonnet and a wide bootbox , screen and uprights, heater, wiper motor etc available separately.
  • 2 months later...
hello
you don’t have or could make a drivers rear wing seiw wide body - removable wing?
all the best
Adrian
FYI there’s 3 versions of “seiw” bodywork so you may need to specify “kit”, “ZK” or “FW” and then there’s std and extra wide arches too!
thank you
i will need to do some measuring
If you send me a picture of your rear arch then I can make you one if I have the correct size mould. Mine are all zk style not the fw. Cheers rich
cheers rich
i have asked garage to measure to be sure
i think it’s zk standard width drivers side rear wing as its 20 year old body seiw wide body with detachable wings
they are 280mm wide
will attach pics after work today
45 minutes ago, AdRock said:
they are 280mm wide
That’s extra wide. It suggests your car is a Sierra SDV model as they required the extra wide arches 👍
here are pics of top of rear arches9C5CB1D0-EC29-47BA-94F8-601691C0DAC4.thumb.jpeg.91a39287b969da38998d43978e476245.jpeg
Pretty sure I have the moulds for them.  I'll check later on
