Dave Eastwood (Gadgetman) Posted March 12, 2022 Posted March 12, 2022 Anyone that's either got spare bits, or gone ITB, have a spare, working Honda OEM TPS they no longer need? Mine's showing signs of wear at idle, and I'm not convinced it will adjust out. A back up would be handy.
Si.Dalziel Posted March 12, 2022 Posted March 12, 2022 5 hours ago, Dave Eastwood (Gadgetman) - Club Secretary said: Anyone that's either got spare bits, or gone ITB, have a spare, working Honda OEM TPS they no longer need? Mine's showing signs of wear at idle, and I'm not convinced it will adjust out. A back up would be handy. If you need one I have one on my old one. I wasn’t really planning on getting rid though but then I don’t have any plans (yet) to put the OEM manifold back on. Have you thought about a bigger throttle body and having the manifold matched???? Tegiwa have a fair few options and have a manifold machining service?
Dave Eastwood (Gadgetman) Posted March 12, 2022 Author Posted March 12, 2022 Have thought about it Si, just covering my bases! 1
Ian Kinder (Bagpuss) - Joint Peak District AO Posted March 13, 2022 Posted March 13, 2022 Do we know if the Honda Type R item is the same and hence suitable? (Yes, I'm suggesting a part K swap ). My S2000 throttle body was damaged by the breaker removing the engine after I'd bought it and a loose throttle body was supplied with the engine. I suspect it was off a Type R.
Dave Eastwood (Gadgetman) Posted March 13, 2022 Author Posted March 13, 2022 No it’s not. Honda type B and D, are supposedly suitable, though you’ll see vague references to small mods being required.
