AlexN Posted February 11, 2022 Posted February 11, 2022 Westfield ZK wide body £14,000 70 Plate 2.0 LTR silver top Zetec on Throttle bodies 450miles since IVA Registered 1.10.20. IVA in September 2020 with non Cat 1993 2.0 Silver top Zetec passed first time. Build record with original receipts and Ford dating letter for the engine on file. The engine is a rebuilt 2.0 silver top Zetec engine with mild porting. The throttle bodies were built by DanST and the ecu in an Omex 600 with Omex loom which has been programmed for IVA pass on 1993 non cat engine. Fitted to a Type 9 standard gearbox with 1.8 Zetec flywheel and new clutch, the diff is 7" Sierra all of which run very well. The alternator is the Burton kit to suit this engine and a new light weight starter motor plus new water pump and new cam belt. A high capacity Coolex Rad with Spal fan on standard Westfield controls. New full size battery to ensure no issues re IVA. Brakes are standard Ford type all new this year with EBC front pads and discs plus standard pads and discs on rear no issues re brake test at IVA. Steering all new again no issues re self centring for test. Shocks are new AVO with 300lbs springs at front and 185 at rear. Fuel system all new with Goodridge Hardine tubing fitted to factory guide lines and factory brake line kit. NewWestfield wiring loom with IVA spec lighting including fog light. Wheels were new with kit 5 spoke Revolution with 195 50 15 Yoko's. In the past 12 months the seats have been upgraded to Westfield sports turbo with orange piping with matching carpets. Quick release steering column from Toybox with 300mm Momo steering wheel. Heater fitted And a custom lockable boot lid powder coated fitted 2021 Westfield side doors. Drives well with no issues. 4
