Kingster Posted January 31, 2022 Posted January 31, 2022 FYI, I am pretty sure that there’s two kinds, early ones that will only accept push in shafts and later ones that will take lobro shafts. 1
Dave Eastwood (Gadgetman) - Club Chairman Posted January 31, 2022 Posted January 31, 2022 Yup, I had the same recollection as Chris.
Allan Cooke Posted January 31, 2022 Author Posted January 31, 2022 I have the early type independent rear suspension with drum brakes can I just change the uprights? I've recently fitted a lsd with uprated sierra drive shaft
Kingster Posted January 31, 2022 Posted January 31, 2022 You’ll need hubs too. The hubs will need to match the driveshafts. The early sierra uprights use push in shafts with a Sierra diff and Sierra hubs. The later ones use lobro driveshafts and have hubs that match the bolt on shafts - not sure what they are off as not got them on my car 😁 If you just want disc brakes, you can get adapter plates that bolt on to your hub bearing carriers.
Allan Cooke Posted January 31, 2022 Author Posted January 31, 2022 This is my original hub with the sierra shaft in it
Kingster Posted January 31, 2022 Posted January 31, 2022 Here’s the sdv upright and hub with adapter - just as an example to show how the adapter plates fit here’s the push in Sierra shafts for comparison to yours
Kingster Posted January 31, 2022 Posted January 31, 2022 If you get disc uprights, you need these hubs for push in shafts
wizzer Posted February 1, 2022 Posted February 1, 2022 Hi Allan 5mm laser cut brackets and spacer Golf caliper just needs a bit of jiggery pokery to make the hand brake work. Definitely the cheapest option. Tony
Kingster Posted February 1, 2022 Posted February 1, 2022 1 hour ago, wizzer said: 5mm laser cut brackets and spacer Definitely the cheapest option. Agreed 👍 And Golf Calipers preferable to Sierra (I’ve had both) 2
Kingster Posted February 1, 2022 Posted February 1, 2022 Your drum brake hubs will need machining to fit under the discs by the way - from memory it’s 134mm dia? Need to confirm that!
Allan Cooke Posted February 1, 2022 Author Posted February 1, 2022 OK thank you I've been over to work on the car tonight I think the issue is I've brought the wrong drive flanges
Crash test dummy Posted February 2, 2022 Posted February 2, 2022 8 hours ago, Kingster said: Your drum brake hubs will need machining to fit under the discs by the way - from memory it’s 134mm dia? Need to confirm that! The conversion that Tony shows above uses Fiesta discs rather than the usual MKIII Escort front. The drive flanges fit under these without machining. 1
