kent crossflow engine mounts wanted
hello
thanks in advance
I don't have any, but which do you want.
The 'standard' Ford ones that were generally oblong in shape that contained the rubber block within it, or the Westfield type, which was a bracket from the block to which you fitted typically a round rubber mount sandwiched between a WF supplied chassis bracket - or doesn't it matter ?.
Hello
What is the part number of the ford part please if you know it ?
Best regards
Are the mounts you want going on the same engine that was in the car already, or is this another block being fitted ?. I ask because if your chassis bracket was fitted with a 711 block, anything older than this (691, 681 etc) will need 10mm spacers between the block and the engine mount.
691 and earlier blocks have narrower mounting lugs on the exhaust side than a 711.
I think I might have a spare pair of the oblong type with the rubber mounts, I'll have a look tomorrow and if I have, I'll send you some photos.
Gareth
