Hayabusa Turbo Installation --SOLD--
Complete Hayabusa turbo solution.
I bought a perfect 2000 miles gen1 busa engine from Yorkshire engines. The engine was stripped for upgrade to kitcar turbo use so the sale is the entire std engine inc throttle bodies etc. plus the following:
  • uprated output shaft to fit Honda sprocket + donut drive flange + donut
  • uprated gear change shafts
  • Nova Racing hydraulic clutch system
  • Nova Racing dry sump + external scavenge pump
  • complete spare gearset
  • new top quality custom turbo manifold for busa made by AAS @ Newcastle
  • new Garret GT2860RS (disco potato!) turbo
  • new Carillo CP4008 turbo pistons + rings
  • 2mm barrel spacer plate
  • new Carrillo rods
  • uprated clutch springs
  • set of new shells to match Carrillo rods to crank
  • uprated 10mm studs
  • APE uprated valve spring set
  • double ended fuel rail
  • APE adjustable cam sprockets
  • manual timing chain tensioner
  • gaskets etc
there's prob other bits which I've forgotten about
£3k
Interested in the Busa parts can you send some photos of the engine Do you know any of the history is it only 2000 miles?  Can yo confirm the engine number?
Hi NDS,
the engine's obv in a hundred bits - taking pics is going to take all day for all the parts and one new carillo rod's going to look the same as the pic you can down load off the web. what parts exactly do you want pictures off?
I can confirm the engine number but what do you want to confirm it against? the engine was complete when I collected it from Yorkshire engines who told me it had done 2k miles and it looks new. I bought it from Malcolm simply because he had a great rep for selling accurately described, quality parts though I'd no way of confirming the true mileage. However, later on I also bought a spare gear set and it's clear that the edges of the dogs are less worn on the Yorkshire engine than the later gearset.
here's some pictures of the turbo and manifold mounted on an old cylinder head
Hi NDS,
  • Dave Eastwood (Gadgetman) changed the title to Hayabusa Turbo Installation --SOLD--
