Raceline sump for Blacktop Zetec
Posted (edited)
I'm after a raceline sump for my 1800 zetech engine as at min its got the standard sump on it
Edited by Ian Kinder (Bagpuss) - Joint Peak District AO
improved title
I don't have one, but is it for a blacktop or silvertop? Same sump casting but different baffles/windage tray etc.
Having bought a used one for a silvertop and converted it, if doing it again I would buy new I think. Not a lot of cost saved because the used one are few and far between, and the baffle plate screws where all stuck in which what i can only assume was stud lock!
Daniel
Oh right it's for a black top zetec
  • Ian Kinder (Bagpuss) - Joint Peak District AO changed the title to Raceline sump for Blacktop Zetec
No idea if this will be any good
Also there are further 2 variants depending on if the starter is exhaust side or induction.  Ginetta used them on the race cars which might help with the search for used.
Andy I have a shallow sump if you are interested,it’s not a race line one but it fits a 1800 Zetec silver top and is 155mm deep and is in good condition also has the oil pick up.there are no bolts or gasket’s included though.i am looking for around the £200 mark plus carriage if you are interested.colin (haflingerman)
