snowy892 Posted December 28, 2021 Posted December 28, 2021 Hi Every one, Unfortunately my Westfield failed its MOT today on 2 items: Repair immediately (major defects): Nearside Front Suspension arm pin or bush excessively worn (5.3.4 (a) (i)) Nearside Front Track rod end ball joint dust cover insecure so that it no longer prevents the ingress of dirt (2.1.3 (g) (ii)) Where do you guys go to get replacements for these a. suspension bush b. track rod end Westfield themselves are not open till the 4th.. Thank you Regards Richard Quote
stephenh Posted December 28, 2021 Posted December 28, 2021 Hi Richard, I can't really answer your direct question, but it will help others who can to know which front hubs you have. Are they the old Ford Sierra ones, or are they the later Westfield alloy hubs? If you aren't sure, the alloy hubs have detachable steering arms, mounted to the hub with 2 (or is it 3?) small studs and nuts, or it might be setscrews. As for the trackrod end dust cover, I should think that is a standard Ford item as the steering rack is a copy of the Ford Escort rack. Quote
snowy892 Posted December 28, 2021 Author Posted December 28, 2021 The suspension arms are wide track.i have attached photos. Quote
Rednop1 Posted December 28, 2021 Posted December 28, 2021 Top ball joint is transit drag link I have a suspension bushes if you struggling 1 Quote
CosKev Posted December 30, 2021 Posted December 30, 2021 You can buy new boots for Ball joints,not sure these are the exact ones you need you will need to check the sizes If you don't want to mess about with boots you can get a complete new joint for not much. https://www.ebay.co.uk/itm/FORD-TRANSIT-Bus-Rubber-Track-Rod-and-Ball-Joint-Boots-Dust-Covers-x2-FREE-Clips-/254770424282?mkcid=16&mkevt=1&_trksid=p2349624.m2548.l6249&mkrid=710-127635-2958-0 Quote
Arm Posted December 30, 2021 Posted December 30, 2021 Bottom joint may well tighten up and be ok. New boot or joint for top as mentioned. Id also look for a new mot man . Strictly he is correct but ......... 4 Quote
snowy892 Posted December 30, 2021 Author Posted December 30, 2021 Thank you everyone for your replies, I spoke with Andrew from Toybox who sent me over the parts I needed, now fitted and hopefully retest tomorrow. The MOT tester was lenient with the emissions and lights!! 2 Quote
Somerset Jim Posted December 31, 2021 Posted December 31, 2021 I was going to agree with Arm as I'd have thought dust cover was an advisory - BUT dust covers easier to fix than emissions Quote
snowy892 Posted January 1, 2022 Author Posted January 1, 2022 On 28/12/2021 at 16:39, Rednop1 said: Top ball joint is transit drag link I have a suspension bushes if you struggling Thank you Rednop1 for the offer, very much appreciated. Quote
