Jitterbug Posted November 24, 2021 Posted November 24, 2021 Garage clear out of few parts. Located in Bristol but happy to post. Speedo with digital mileage gauge £50 Switches £10 2016 Tandem Brake Master Cylinder £100 2016 Clutch Master Cylinder £30 Pair of Genuine Westfield build stands, some very light surface rust from storage (these don't come supplied painted) £50
Jitterbug Posted November 24, 2021 Author Posted November 24, 2021 20210411_113321.jpg 20210411_113323.jpg 20210411_113325.jpg 20210411_113334.jpg 20210411_113337.jpg 20210411_113340.jpg
TV5R Posted November 26, 2021 Posted November 26, 2021 Hi interested by the speedo and switch ? Speedo 80 mm ? Mileage ? best regards
GaryH Posted November 28, 2021 Posted November 28, 2021 Hi, what's the bore size of the clutch master cylinder? Gary
Jitterbug Posted November 29, 2021 Author Posted November 29, 2021 On 25/11/2021 at 01:14, Exige man said: Hi is you're fuel tank still available Tank is now sold. Thanks for your interest.
Jitterbug Posted November 29, 2021 Author Posted November 29, 2021 On 26/11/2021 at 13:05, TV5R said: Hi interested by the speedo and switch ? Speedo 80 mm ? Mileage ? best regards Hi, yes 80mm diameter. The mileage is just over 3000 miles - see pic below. This was sent to me by the breaker I bought it from, he advised it came from a 2015 car he was dismantling.
Jitterbug Posted November 29, 2021 Author Posted November 29, 2021 18 hours ago, GaryH said: Hi, what's the bore size of the clutch master cylinder? Gary Hi Gary, I am not sure how to calculate this, if you can advise I can measure it. These came from a factory 2016 car, I believe they are the stock standard items fitted.
GaryH Posted November 29, 2021 Posted November 29, 2021 Thanks for getting back to me. I'll see if I can find out. Gary
TAFKARM Posted November 29, 2021 Posted November 29, 2021 Is there a part number on the bottom of the brake master cylinder?
Jitterbug Posted November 29, 2021 Author Posted November 29, 2021 Right checked both, there is nothing written or stamped into the clutch master cylinder. The brake cylinder I believe is AP racing branded as it says; AP 321 405C 15 (this could be 16) stamped on one side. The other side says FC2A This matches the photo on the parts website; https://parts.westfield-sportscars.co.uk/index.php?route=product/product&product_id=84&search=brake+cylinder&description=true Then there is a metal ID tag which has stamped L39K LBBHGL033A 3.0 on it. Not sure if that is an internal manufacturing code.
Stuart Posted November 29, 2021 Posted November 29, 2021 3 hours ago, Jitterbug said: Hi Gary, I am not sure how to calculate this, if you can advise I can measure it. These came from a factory 2016 car, I believe they are the stock standard items fitted. Standard clutch M/C is 5/8"
TAFKARM Posted November 29, 2021 Posted November 29, 2021 1 hour ago, Jitterbug said: Right checked both, there is nothing written or stamped into the clutch master cylinder. The brake cylinder I believe is AP racing branded as it says; AP 321 405C 15 (this could be 16) stamped on one side. The other side says FC2A This matches the photo on the parts website; https://parts.westfield-sportscars.co.uk/index.php?route=product/product&product_id=84&search=brake+cylinder&description=true Then there is a metal ID tag which has stamped L39K LBBHGL033A 3.0 on it. Not sure if that is an internal manufacturing code. Worth a punt ? @Andy - a15cro
Andy - a15cro Posted November 29, 2021 Posted November 29, 2021 16 minutes ago, Rush Motorsport said: Worth a punt ? @Andy - a15cro Yes don’t see why not. Message incoming
Dave Eastwood (Gadgetman) Posted November 30, 2021 Posted November 30, 2021 That looks more like a stock AP master cylinder, not the AP Racing version. (They’re actually two completely different companies, now a days.)
