more computer questions
Richard (OldStager)
hi all,
i was given an old laptop over the weekend and was told if i can get it working i could have it. i am typing on it now - however...
the two usb ports don't work, this isn't software related - drivers etc, but a hardware issue.
basically this laptop was a childs play thing for a year or so and all the ports and stuff you need to plug into it in order to function are trashed, the reason i was given it was the broken charger socket - this i have now repaired. but the two usb ports are all bent and have missing pins , so an easy fix is next to impossible .
so my question
the only port that works is the sd slot, so is there some sort of adapter that will plug into the sd slot and then have a usb connector on the end of it, so i can use a normal mouse , also if i could have a working usb i can then use this laptop for programming car stuff rather than using an aged and bulky old pc.
i have tried to google for such adapters but unable to find what i need, i already have a usb to sd adapter, so surely there must be a sd to usb...
anyone seen or can tell me where to get one.
i have no issues making my own if thats what it takes, but thought i woulod ask the experts here first.
thanks.
richard.
Link to comment
SD is a memory card format. Hence why you can buy a USB device than can read SD cards, but you won't be able to convert a SD slot into USB, sorry.
Best bet will be to fit new USB sockets to the motherboard but careful soldering and the right sockets will be needed.
Link to comment
ah thanks, that may explain why i can't find one then. i have the pinouts for both and both have the same connections with the exception of the sd card having an extra data channel, i did find some project pcb's that claimed it would do what i wanted but they seemed quite bulky for what i need.
I suppose this could just be a backup way to get on the internet etc, should the main pc fail. I will see how easy it will be to replace the ports, but with my eyesight being quite bad looking at small things i don't think i would be able to do it myself.
thanks anyway.
Link to comment
Bright light and a magnifying glass! I'm in that club too!
Link to comment
How old is old? Does it have Bluetooth? If so look for a Bluetooth mouse and any other peripherals that might fit the bill.
Link to comment
hi, not sure exact age, sticker on it says it was designed for windows 7, although its on 10 now. it doesn't have bluetooth sadly as that was my first though as well. i'll drag out the magnifying glass this week and see how easy the ports are to replace, trouble is most modern pcbs are built and soldered by machines so are ultra small at the soldering point. i have several small irons for pcb work, not sure i have one small enough for this modern generation of them.
Link to comment
cheers chris, i have the old mech suck type ones, i think the issue is going to be my eyes rather than hardware, i am due an eye test very soon, this has been cancelled so many times due to covid, grrrr.
Link to comment
17 minutes ago, pistonbroke said:
Make and Model would help !
acer aspire 5332, not going to attempt the mod until i get my eyes sorted, but i have done piles of pcb work in the past - but that was 20 years ago when i could see 🤣
Link to comment
https://www.ebay.co.uk/itm/171804363261?epid=1160678811&hash=item28005689fd:g:WwwAAOSwNzNhA0xK
Link to comment
ah, thank you ian, i see from the photo there is just the 4 connections to the board. this explains why one port although looking ok doesn't work, they must be linked internally and given the other port is totally wrecked those links must be broken.
Link to comment
Last job I did on an SMD connector was about 6 months ago replacing the Micro USB socket on an old Kindle tablet. Thankfully I have a binocular microscope…..
Link to comment
