david.c Posted February 12, 2004 Posted February 12, 2004 Thought this one was worthy of the board. There is a Space Shuttle mission to the moon with TWO monkeys and a woman on board. The ground control centre in the US called: "Monkey number 1, Monkey number 1 to the television screen." The monkey ran to the screen and sat down. The controller then said: "I want you to release the pressure in compartment 1, increase the temperature on engine 4 and check the oxygen flow to the reactors." The monkey 'screeched', then jumped up and released the pressure, increased the temperature, and checked the oxygen flow. A few moments later the ground control centre called again: "Monkey number 2, monkey number 2 to the television screen." The second monkey ran to the screen and sat down. The controller said: "I want you to add Carbon Dioxide to room 4, stop the fuel injection to engine 3 and calculate the level of solar radiation." The second monkey 'screeched' jumped up and added the carbon dioxide, stopped the fuel injection and calculated the solar radiation. A few moments later ground control called again: "Woman, to the television screen. Woman to the television screen." She came to the screen and sat down, and just as the controller was about to tell her what to do she said... "I know, I know! Feed the monkeys, and don't touch anything!" David Quote
neilwillis Posted February 12, 2004 Posted February 12, 2004 That's terrible, surely it would be remove carbon dioxide, and not add it! Quote
david.c Posted February 12, 2004 Author Posted February 12, 2004 The controller said: "I want you to add Carbon Dioxide to room 4, Room 4 might have been where they kept their 'Soda Stream' drinks maker. David Quote
taffy Posted February 12, 2004 Posted February 12, 2004 Brilliant In view of what happened to my keys last week that just about F**in right as well! Rob Quote
