Sold - Duratec to mx5 mk3 gearbox conversion kit
For anyone considering dropping in a Duratec over winter this kit let’s you bolt the mx5 mk3 (NC) box direct. The kit converts the external fork type clutch cylinder to a concentric type so the gearbox will fit in the tunnel.
Not suitable for narrow body tunnels.
Items included:
- Machined billet front gearbox plate
- concentric slave cylinder assembly
- remote bleed pipe and braided hose
- mk5 mk3 (5 speed) flywheel and bolts
- Lux clutch and pressure plate
- Westfield sport 250 gear lever (so it doesn’t hit the dash) (£137 RRP)
Kit and clutch have done 2000miles before I upgraded my engine and gearbox.
To be clear this does not include engine or gearbox. Although you are free to take a spare gearbox that requires new thrust bearings. (Squeals a little in 5th)
£150
Collection only from leyland, lancs
  • Aeruttle changed the title to Duratec to mx5 mk3 gearbox conversion kit
7 hours ago, Aeruttle said:
Not suitable for narrow body or mt75 tunnels.
I suggest an edit... It can be used in MT75 tunnels if you cut an access hole in the flat alloy part of the scuttle above the concentric kit bleeding valve.
I know because I've done it.
Thanks Tim now edited
PM'd 👍
  • Aeruttle changed the title to Sold - Duratec to mx5 mk3 gearbox conversion kit
