Garridge floor covering
Two pack, epoxy paint gets my recommendation.
Mines been down 18months and hasnt lifted AT ALL...
The stuff I've got is called Penguard Jotun, I got it from Lawsons Paint and Racking in Southampton.
Seconded. Top stuff :love: . And it doesn't need any of that p******** about prepping the floor or sealing it. Just sweep it out and run a hoover over it, then paint away! :)
And if you lay a self levelling screed material you still gotta ensure the base concrete is throughly cleaned of all contaminates - road salts, crud and oils.
Failure to clean causes the "topping" to curl from the base concrete, at least.
Fosroc and Sika do various materials for such an undertaking  ;)  :D  ;)  All to be installed fully in accordance with the specialist manufacturers current technical specification and data  ;)  ;)
That'll be 100 guineas please  :D  :D  :D  ;)  ;)  :devil:  :devil:  :D
Oh and PeePots right about vinyl flooring - mildewy and naff
Ooim a builder see.......
Any paint is only as good as the surface its adheres to.
Therefore a friable surface will not offer a key ie concrete.
Simple really, go to your local builders merchants and buy a tin of concrete floor surface hardner/sealer.
This seals/solidifies the top surface so that you can paint easily.
Then go and buy an industrial quality floor paint, easily applied, easily cleaned, easily recoated.
