AN-6 aeroquip type connectors
Before I start trawling tinternet does anyone have any AN-6 aeroquip style hose connectors which are surplus to requirements.
Not too fussed about colour or make.
Phil
I cant help with your request but having just AN'd my oil and fuel system, unless you're trying to save grams, I'd get the hoses made in steel by a local hydraulic place.
I had one done, yes a little heavier, but way more durable IMO, the fitting doesn't get scratched, they don't leak because they are crimped on and the crimp has a burst pressure of 1800 psi...
And it was cheaper.
Ok thanks russ.
I already have braided motorsport hoses fitted and AN fittings on the high pressure side of the system but planned to change the fittings on the low pressure side to my swirl pot as the existing jubilee clips do get the odd leak.
Its def worth considering tho if I upgrade the hoses in the future.
Did the air intake work?
Phil
Phil
Its doing a great job of channelling the air into the box its still sat in :)
  • Haha 2
Ok thanks glen.  Appreciate they're not particularly expensive till you add up how many you need.
Phil
I used the motamec fittings in my build and they work a treat at a very good price. https://www.motamec.com/
Agree 100%, can't fault them. Not sure what the setup is but I was under the impression the brand is part of Motorsport Tools as all my fittings are branded Motamec ordered from Motorsport Tools.
I also have some spare still brand new but I don’t where they are right now. Will dig through the the post build pile later.
Actually there’s a topic “How big was your post build pile”
  • Haha 2
That was the theory behind my thread.
They're the sort of bits everyone has spare but can't be bothered to get rid of so sit unloved in a draw/pile somewhere.
Sorry mate, I failed.....I thought I had more than I do as I normally over order but clearly not this time🤔
No worries glen, thanks for looking.
I have a good selection.
Exactly what do you need?
Nothing fancy,
AN-6 straight couplers for standard braided hose, not ptfe.
I need 10 in total to upgrade the plumbing on my fuel system.
