Post Build Clear Out
Have a few bits and bobs lying around the garage after finishing up my build…hopefully of use to others…
Items can be collected from Broxburn, West Lothian or postage at buyers expense (I’ll get individual quotes for those interested once I get a post code)
Pair of Willans Supersport Westfield harnesses
4 point
Red
2” straps
Comes with eyebolts for the top
I would be 99.9% sure that they are out of date for any proper racing (tags have also been cut off)
They have already been scrubbed with Woolite and pressure washed…they’ve came up a lot better than they were but still some marks in places…
£80
AVO Shocks and Springs
12” Open
9.64” Closed
2.25” Springs
8” Long
172 lbs/inch
Recently serviced by AVO
Springs recently powder coated
£100
Springs
1.9” ID
7” Long
255 lbs/inch
Recently powder coated
£20
Radiator Fan Switch
92 - 97 degrees
Unused
£10
Land Rover Defender Clear Indicator Lens x2
With orange bulbs 21W
SOLD
Escort Steering Rack Boots
Brand New
SOLD
Rear Light Lens
Only 1 available
Used but good condition
£5
Set of switches
Lights, Fog, Fan, Wipers, Washer
A bit faded but they all worked before I stripped the car down.
SOLD
Boot Box
ZK bodywork…maybe others but I’m not sure
Some black adhesive still on there…it does come off…I’ll have a go at that tomorrow and post better pictures.
SOLD
80mm VDO Tacho
7k rpm
Comes with plug and pig tail
SOLD
52mm VDO Oil Pressure gauge
5bar
£20
Sterling Touch Immobiliser
No real info on this other than I removed it from the car…
Quick look online and it is apparently Thatcham Cat 2
1x fob
£40
I will no doubt find some more…will update this thread when I do
Postage price for the switches to b77 please
@elrik do you still need steering rack boots?
£2.50 with Hermes 👍
Hi, I’ll take the indicator lenses and the rack boots if they are available. LE10 2AS
Rack boots are sold.
Indicator lenses will be £8.00 posted.
PM me for payment details.
Also available
Inner Upper Steering Column, Quick Release, Spacer & 300mm Suede Steering Wheel
I replaced this with a GoRace column and QR from Westfield as this QR button was catching my rev counter bezel slightly…theres also some slight play in the QR (video below).
Might still be of use to someone? The play wasn’t that noticeable while driving to be honest.
Column is an ‘Allegro’ type, 9/16” x 32 splines.
SOLD
