Fuel pipe
When I went for SVA at Manchester the examiner insisted on being able to read markings on all flexible fuel pipes to confirm it was rated for fuel use.  Mine was Ok but the guy ahead of me failed as he had used unmarked pipe.  I think it was clear pipe with reinforcing mesh.
Rick
Done a search, here  looks like I've got another problem    the rigid copper pipe is 5/16. If I read the Think Automotive website correctly -6 JIC is for 3/8 tube   is this correct?
What's a 1/16 of an inch between friends eh?
ian
just finished mine today i have 5/16 copper pipe and needed to get to -6jic rang loads of places and gould not get nothing to fit, in the end i went to a company called pirtek they sell hydrolic(sp) fittings etc and they made an adapter to go from 5/16 to -jic had four of these and payed £10 cash
adam
Think do a load of adaptors as well, but Pirtek will probably be cheaper.
Adam did you flare the ends of the coper pipe or did you use flareless fittings ?
they are compresion fitting onto the copper pipe,is this wot you call flareless
adam
Cheers guys - got me out of the s***e  :D  :D
Roll on first engine start next weekend  :D  :D  :cool:  :love:
Ian.
adam
Any chance of the part numbers ?
sorry no part numbers it was a cash deal  :D
I used the WF supplied pipe for the the supply(steel) and 8mm copper for the return (from B&Q)
I soldered a compression fitting olive on the end of the copper pipe to allow a better grip for the rubber pipe. I Used proper fuel hose clips in the engine bay with correctly marked high pressure fuel hose. I also covers the hose in plastic shielding. I used jubilee clips in the boot area for the pump/swirl pot etc.
It passed SVA no problem on these things at the Croydon centre. The examiner didn't remove the covering to check the fuel pipe but I think he clocked all the correct clips.
the compression fitting olives are avaialble from any plumbers and (b&q) they are for microbore central heating pipe (8mm)
