New toy GBS Zero
Hi All
i sold my formula 27 BEC the other week and have now just bought a GBS Zero with a 2.0L redtop with twin 45’s , IRS 7 inch diff Sierra calipers discs and hubs
it has a full cage and a decent spec
it has a etb race dash and omex Rev limiter
hopefully get it on a couple of trackdays soon and next year
Looks good, I hope you have fun with it 😀
Just really watch the oil pressure when on track with a C20XE, especially under braking given the tyres you have on it.
  • Craigib76 changed the title to New toy GBS Zero
It has a shallow sump and remote filter and oil cooler
how Best to monitor the pressure
I have an available port on the digi dash I can use if this is the best way
regards Craig
I would say there really is no best way, it will come down to personal preference.  I bought a standalone unit from Spa Designs and also a very bright pressure warning light that triggers at 21psi.
If you can do it through the dash and get a suitable (very visible) low pressure warning that will be the least effort.
If it is the usual finned shallow sump you will like need baffling for track use, without it you can watch the oil pressure tumble as you brake and it long corners.
regards Craig
just be aware that i had the same dash a  few years ago and the oil pressure never read correctly. i fitted a stack mechanical gauge as a backup just to be certain. it looks like  a cracking car though i did see it for sale on facebook and thought how good it looked
  • 4 weeks later...
I have no problems with oil pressure and no oil cooler, as long as you have a baffled sump and windage tray you’ll be ok. Just need to keep the oil level at max on a trackday, checking at lunch time.         Red tops rock!
Been looking through the folders of receipts and info for the car and found that the sump is from SBD Motorsport,
it is a baffled shallow sump
i will look at fitting another sensor or sender and gauge
cheers Craig
