Sparky Posted August 16, 2021 Posted August 16, 2021 Looking for a cage and Westfield aluminium uprights/hubs Anyone got these lurking in the garage?
Martin Letts - Joint Hampshire & IOW AO Posted August 17, 2021 Posted August 17, 2021 There’s a cage on the parts for sale, it’s for a narrow though
Sparky Posted August 18, 2021 Author Posted August 18, 2021 Hi Martin, Yes I saw that I need a wide body one, unfortunately
Westfield Chesil Limited Posted August 19, 2021 Posted August 19, 2021 We have a cage on site without side mounts if this is of any use.
Sparky Posted August 25, 2021 Author Posted August 25, 2021 On 19/08/2021 at 08:34, Westfield Parts Dept said: We have a cage on site without side mounts if this is of any use So how does it mount, would it need additional fabrication to the cage? or just brackets fitting, I need it for a Megablade chassis?
Westfield Chesil Limited Posted August 25, 2021 Posted August 25, 2021 Some vehicles were spec'd with side mounts already installed. If you have one of these chassis then the side mounts arent requried as you already have them installed.
Sparky Posted August 26, 2021 Author Posted August 26, 2021 I have no side mounts so guess this is not compatible, although planning lots of work over the winter, How much is the cage and can you send pictures please?
Mark Hughes Posted August 26, 2021 Posted August 26, 2021 Hi how much is the cage without the side mounts? On 25/08/2021 at 08:44, Westfield Parts Dept said: Some vehicles were spec'd with side mounts already installed. If you have one of these chassis then the side mounts arent requried as you already have them installed.
Westfield Chesil Limited Posted August 27, 2021 Posted August 27, 2021 Morning, The cage is the same as shown on our website. If you have no side mounts installed the betyter route would be to buy a new one witht he side mounts as they are required for installintion of the cage. Repowder coated cage £850.00 with new FIA sticker.
Deano85 Posted August 30, 2021 Posted August 30, 2021 On 27/08/2021 at 08:21, Westfield Parts Dept said: Morning, The cage is the same as shown on our website. If you have no side mounts installed the betyter route would be to buy a new one witht he side mounts as they are required for installintion of the cage. Repowder coated cage £850.00 with new FIA sticker. Potentially stupid question. How do I know if I have the mounts already? Can you provide an image or diagram please?
Rednop1 Posted August 30, 2021 Posted August 30, 2021 52 minutes ago, Deano85 said: Potentially stupid question. How do I know if I have the mounts already? Can you provide an image or diagram please? Some of the current spec chassis manufactured in the last two years already have the side mounting bars welded in
Deano85 Posted August 30, 2021 Posted August 30, 2021 1 hour ago, Rednop1 said: Some of the current spec chassis manufactured in the last two years already have the side mounting bars welded in Thanks. That's not mine then.
