richardhowe Posted August 14, 2021 Posted August 14, 2021 SOLD SOLD SOLD The time has come to sell my Westfield SEIW kit car, I built the car in 2003 from a starter kit using donor parts for an age-related plate (G reg). I originally built is using a C20XE red top with 45’s then changed to a C20LET for more power, a mate who’s an engineer helped me with the conversion and made the necessary custom parts to fit. I took it to AutoMark in Stokesley to get a remappable chip fitted and tuned, the car has been dyno’d at 260bhp. The head was ported and flowed by CAS Engineering in Northallerton, ARP bolts were fitted when fitting the lowered Westfield alloy sump. The gearbox is standard Ford Type 9 with Westfield bellhousing to fit the Vauxhall engine. The rear diff is a Sierra Cosworth LSD 3.6. The car has been garaged all it’s life, since having kids and building a house over the last 4 years I’ve barely used it. I’ve only covered 600-700 miles since 2014 and it’s currently 6749 miles since built. I spent nearly £3K in 2016 on new Compomotive 13” CXR’s with Toyo R888r’s, full roll cage and carbon Tillett seats. I have a huge folder of receipts from day one and loads of photo’s the build and it’s life. I'm looking for £12000 Mileage is 6749 MOT’d 22/05/21 The spec is as followed: Westfield SEiW 2003 Starter Kit Vauxhall C20LET Custom 4 core Pace Charge Cooler Pre Rad and Pump Westfield Radiator for 2.0 Vauxhall Ford Type 9 Gearbox Ford Sierra Cosworth LSD Diff 3.6 Custom made by JP Exhausts Front CAT Motorsport 4 pot callipers Rear Sierra callipers Westfield Alloy Front Uprights Westfield Anti-Roll Bars Front and Rear Full Playskool Motorsport Roll Cage Tillett Carbon B6 Seats with Playskool 4 point harnesses 13” Compomotive CXR wheels 7” wide ET18 with Toyo R888r’s Detachable rear arches with fiberglass carbon rear guards Westfield OHC V8 Shocks and Springs Playskool Motorsport suspension setup and corner weighted Odyssey racing battery mounted above the Diff Removable Sparco steering wheel Westfield flat vinyl dash Lots of other stuff so ask questions if you have any. 3
markcwalker Posted August 15, 2021 Posted August 15, 2021 21 hours ago, richardhowe said: The time has come to sell my Westfield SEIW kit car, I built the car in 2003 from a starter kit using donor parts for an age-related plate (G reg). I originally built is using a C20XE red top with 45’s then changed to a C20LET for more power, a mate who’s an engineer helped me with the conversion and made the necessary custom parts to fit. I took it to AutoMark in Stokesley to get a remappable chip fitted and tuned, the car has been dyno’d at 260bhp. The head was ported and flowed by CAS Engineering in Northallerton, ARP bolts were fitted when fitting the lowered Westfield alloy sump. The gearbox is standard Ford Type 9 with Westfield bellhousing to fit the Vauxhall engine. The rear diff is a Sierra Cosworth LSD 3.6. The car has been garaged all it’s life, since having kids and building a house over the last 4 years I’ve barely used it. I’ve only covered 600-700 miles since 2014 and it’s currently 6749 miles since built. I spent nearly £3K in 2016 on new Compomotive 13” CXR’s with Toyo R888r’s, full roll cage and carbon Tillett seats. I have a huge folder of receipts from day one and loads of photo’s the build and it’s life. I'm looking for £12000 Mileage is 6749 MOT’d 22/05/21 The spec is as followed: Westfield SEiW 2003 Starter Kit Vauxhall C20LET Custom 4 core Pace Charge Cooler Pre Rad and Pump Westfield Radiator for 2.0 Vauxhall Ford Type 9 Gearbox Ford Sierra Cosworth LSD Diff 3.6 Custom made by JP Exhausts Front CAT Motorsport 4 pot callipers Rear Sierra callipers Westfield Alloy Front Uprights Westfield Anti-Roll Bars Front and Rear Full Playskool Motorsport Roll Cage Tillett Carbon B6 Seats with Playskool 4 point harnesses 13” Compomotive CXR wheels 7” wide ET18 with Toyo R888r’s Detachable rear arches with fiberglass carbon rear guards Westfield OHC V8 Shocks and Springs Playskool Motorsport suspension setup and corner weighted Odyssey racing battery mounted above the Diff Removable Sparco steering wheel Westfield flat vinyl dash Lots of other stuff so ask questions if you have any. Lovely 1
Cosworthlee Posted August 16, 2021 Posted August 16, 2021 Very smart be it goes like a rat up a drain pipe 1
Kingster Posted August 16, 2021 Posted August 16, 2021 That’s a whole lot of car for the money! GLWS 1
