Weber parts.
Looking for the fitting that secures the throttle cable into this lever. Also, a set of washers that retain the trumpets to the carbs.
Mine uses a rod linkage, but you can get them here it appears
They do Weber spares as well incase you thought it was Del only..
https://www.dellorto.co.uk/shop/dellorto-car-carburettors-parts/parts/dhla-parts/wes21-lotus-lever-cable-retainer/
Not sure which washers you want, sprung or solid
Sprung here
https://www.dellorto.co.uk/shop/weber-carburettors-parts/carburettor-parts-weber-carburettors-parts/idf-parts/spring-washer-6/
Not the most friendly of sites to work with, I found the linkage then it said search for part number of barrel, but then didn't give the number , GRrrrr
Fast Road Cars in Abercarn South Wales is who I use on a weekly basis , Anthony , Tel 01495 237456 or 07900 373389 , normally has it in stock
