Dave Stirrup Posted July 26, 2021 Posted July 26, 2021 Parts not needed after Pinto rebuild. 1/ K&N 83mm small oval air filters x2. Fitted never run. Some small marks to filters from fitting see photo. come with new gaskets (The boxes are from a smaller set so will have wrong part number on) £120 posted (No Offers) 2/ Pinto DCOE 45 inlet manifold. Fitted never run. Comes with new studs, spring washers and O rings. I have tried to show the extension and lift in the photo's. Contact me if you want different pics. £120 Posted. SOLD 3/ MotorSports tools Pinto Works alternator bracket. New fitted never run. Well made and ideal for pinto powered road car. £50 Posted. 4/ Omex 140mm 36-1 trigger wheel and Webcon Sensor. New never fitted. £35 posted. SOLD
The_Baron Posted August 1, 2021 Posted August 1, 2021 Morning Dave can you tell me the length (Longest axis) of the filters. if they fit without having to cut the bonnet hole bigger I will be interested. cheers Rowan
Dave Stirrup Posted August 2, 2021 Author Posted August 2, 2021 On 01/08/2021 at 09:53, The_Baron said: Morning Dave can you tell me the length (Longest axis) of the filters. if they fit without having to cut the bonnet hole bigger I will be interested. cheers Rowan Hi Rowan. Hope this helps. Dave
The_Baron Posted August 3, 2021 Posted August 3, 2021 Thanks for the measurements, unfortunately to wide otherwise I would have been interested. Regards Rowan
