So at the recent track day at Blyton I managed to melt my wscc jacket to my exhaust. It's looking like it's needed to be sanded back and re-polished. What's the chances of getting it back to original condition or is it toast. IMG-20210709-WA0000.thumb.jpeg.696c8ce11a0754cdac24d717e1e62bec.jpeg
It’s not toast it’s nylon 🤣
I would apply some heat and try to soften the material first wipe off as much as you can, I’d avoid heavy abrasives, if be trying hard sponge/polishing machine and cutting paste first. I would say it’s salvageable although you may have a faint stain left. Don’t sand, the scratches will certainly ruin the stainless.
Completely fixable, unlike the jacket!
Being careful of the fumes, melting synthetics can be nasty, with a bit of heat ans a softish plastic scraper, you can probably get more off.
Then it’s just a case of how far back with abrasives you need to go. I’d try with just a polish first though, and if that doesn’t do it, relative fine grade wet and dry first, and if that doesn’t fix it, go a step courser.
once you’ve got it off, come back up through the grades to fine, then machine polish with a proper polishing wheel and polishes for stainless.
Not true, but you do really need a proper mop and compounds to take it back to a proper polished finish again. Fortunately you can get small kits from the like of Frost’s that will do it, and polishing mops and arbours that will fit a drill, rather than needing a bench top polisher - though that’s ultimately faster/better.
Nice shoes... Keep them away from the exhaust
  • Haha 2
In ‘sand’ I was talking taking some 40/60 or 80 ‘high abrasive’ type grit to it. I consider wet and dry more of a ‘flat’ but then that’s the environment I learned my trade in many years ago. 😁
Yeah I always think of “sandpaper” in terms of the really coarse abrasive stuff that will leave deep scratches - and “wet n dry” as the stuff used to finely abrade things 😁👍
If you badly dangler it up you can always use scotchbrite pad and make the entire thing “brushed steel” (which looks better anyway IMO!)
Fair enough! 😄 I reckon if you needed to go that course on a silencer, you've probably already totalled the can, you're right!
Thanks for tips guys. Safe to say I will be more carful where I place things
This works a treat & also takes all the discolouration off.
