Ginner Posted July 9, 2021 Posted July 9, 2021 First outing at blyton went pretty well had a couple of issues with gear changes when it was hot Oil and water temps up abit higher than what I’m comfortable with but it all in all a good day Quote
Ginner Posted July 9, 2021 Author Posted July 9, 2021 Yeah very good not sure tbh it it’s like it had a hissy fit when it got hot lost drive couldn’t get a gear and when I did get a gear it said I was in neutral but limped it back and let it cool down and took it out for another kicking Quote
Morley Posted July 9, 2021 Posted July 9, 2021 Yes to find cause neutrals maybe. Was clutch ok? With hot oil? Quote
Richard (OldStager) Posted July 9, 2021 Posted July 9, 2021 Ambient temps were relatively high I believe, sounds like the oil was too hot, what spec do you use?. Quote
Ginner Posted July 9, 2021 Author Posted July 9, 2021 Shouldn’t matter about clutch with clutch less shifts ? when I say hot it was 117 I think Quote
Ginner Posted July 9, 2021 Author Posted July 9, 2021 Just now, OldStager said: Ambient temps were relatively high I believe, sounds like the oil was too hot, what spec do you use?. 15/50 ester Quote
Ginner Posted July 9, 2021 Author Posted July 9, 2021 Need to find away of cooling the thing down Quote
Richard (OldStager) Posted July 9, 2021 Posted July 9, 2021 Just now, Ginner said: 15/50 ester Oh is this a BEC? Sorry I haven't read any of your other posts... Quote
Richard (OldStager) Posted July 9, 2021 Posted July 9, 2021 Ah, well that's me out of the conversation then ... I am sure some seasoned folks will advise you far better than I . Quote
Morley Posted July 9, 2021 Posted July 9, 2021 I’ve found oil made a massive difference to my clutch but it also wasn’t completely disengaging. So burnt out. oil pressure ok now? Quote
Ginner Posted July 9, 2021 Author Posted July 9, 2021 Oil pressures fine just keeping it cool is my main issue Quote
Morley Posted July 9, 2021 Posted July 9, 2021 Mine runs warm we will have to compare temps mate Quote
