SOLD 4age engine and install parts
deposit taken on engine
I bought this off a fellow wscc member who used it for sprints/hillclimb.  Sadly having to advertise due to change in circumstances.
The engine was originally built by Russ Tyler. Since had refresh by auto tech - very little use since.
ARP head studs, bearing and rod kits
Ported head
Cat cams
Cat Adjustable verniers
Rebore to 81mm
Wosner forged pistons
Forged rods
balanced crank and rods
new oil pump
Surfaced Head and Block chemically cleaned
valve spring seat machine to equalise pressure.
new springs retainers followers.
inlet manifold port matched to head.
fidanza lightweight flywheel
AP clutch plate
flos  crank sensor and trigger kit
Modified sump with wings
athena head gasket
HKS cambelt
covers have been modified to connect to alloy catch tank which is included.
inlet for dcoe/dhla
engine mounts for Westfield. May need modifying depending on chassis and position of engine.
alternator
starter motor
Silicone water hoses inc take offs for expansion tank
last time on dyno was around 197bhp
Prov sold
  • Emeny changed the title to SOLD 4age engine and install parts
