Raw Striker 4AGE 20 valve factory built 2007
2007 year manufactured striker, factory built vehicle with high spec, on an age related plate properly registered as a raw striker and its on a 07 number plate.
This is a superb driving car, the 4AGE engine revs to 8300 rpm and is a real screamer and with 300 bhp per tonne make this exciting and fun to drive and sticks to the road very well. On trackdays it can keep up with modern Caterhams costing 3 times as much.
*ENGINE*
Toyota 20v VVT silver top on throttle bodies with 50mm inlet trumpets, piper X filter and alloy base plate, big wing sump.
OMEX 600 mappable ECU will support a future turbo/supercharged set up.
Rolling road print out at a very heathy 151bhp.
Recent gates cam belt and roller tensioner fitted, oil changed regularly, stainless 4 in 1 exhaust system, alloy catch tanks and radiator header, oddesey capacity racing battery and cradle.
*RUNNING GEAR*
Independent double wishbone suspension front and rear. Ford type 9 heavy duty box, paired with LSD rear diff.
New RS 2000 uprights, steering arms, alloy hubs and big bearings, all new rose joints, track rod ends, new correct off set wheels and a full geometry set up, and many hours getting this car to handle just right.
Protech Light weight alloy coil over shocks all round.
Wilwood superlight forged 4 pots / high spec ultralight 2 pots front and rear with new EBC green stuff pads all round. Front and rear discs. New 19mm master cylinder.
*BODY*
In original condition factory yellow gel coat and black powder coat main body panels, Raw supplied new hard side screens, rear boot cover, comes with full soft top hood. New front cycle wings.
Vinyl trimmed bucket seats, full dash board and gauges.
LED light pack.
Battery master switch solenoid isolator.
MOT until August 2021
£8995
Phone 07737543553
