Allan Cooke Posted June 24, 2021 Posted June 24, 2021 Wanted V8 engine mounts and engine loom possibly interested in ecu im converting my cvh to V8
Allan Cooke Posted June 24, 2021 Author Posted June 24, 2021 39 minutes ago, DamperMan said: Strapping 2 cvh’s together to make a 3.2 It might be a little bit on the heavy side 😆
Quinten Posted June 24, 2021 Posted June 24, 2021 This isn't really the place for it, but I'm curious to see what you're planning to do with your chassis to fit a V8 and gearbox in a, what I assume, standard wide body?
Richard (OldStager) Posted June 24, 2021 Posted June 24, 2021 43 minutes ago, Exige man said: It might be a little bit on the heavy side 😆 i bet there would not be that much in it given you wouldnt be using two whole cvh's, wiki has some figures. the motorbike guy on yt alan millyard i think his name is, has done lots of 4 cyl to v8 conversions by using 2, 4 cyl's, clever bloke.
Allan Cooke Posted June 24, 2021 Author Posted June 24, 2021 I've already brought a V8 30 minutes ago, OldStager said: i bet there would not be that much in it given you wouldnt be using two whole cvh's, wiki has some figures. the motorbike guy on yt alan millyard i think his name is, has done lots of 4 cyl to v8 conversions by using 2, 4 cyl's, clever bloke. 30 minutes ago, OldStager said: i bet there would not be that much in it given you wouldnt be using two whole cvh's, wiki has some figures. the motorbike guy on yt alan millyard i think his name is, has done lots of 4 cyl to v8 conversions by using 2, 4 cyl's, clever bloke.
Richard (OldStager) Posted June 24, 2021 Posted June 24, 2021 cool, but my comment was just a reply to your heavy bit, as i dont think it would have been over what you have there, but good luck with it all, you may wish to start a build thread on the conversion.
Allan Cooke Posted June 25, 2021 Author Posted June 25, 2021 8 hours ago, Quinten Uijldert - Webmaster said: This isn't really the place for it, but I'm curious to see what you're planning to do with your chassis to fit a V8 and gearbox in a, what I assume, standard wide body? Yes my chassis is a standard wide body?
TableLeg Posted June 25, 2021 Posted June 25, 2021 I think I may still have a pair of new engine mounts. I'll have a look over the weekend but I might have thrown them away... 1
Dave Eastwood (Gadgetman) Posted June 25, 2021 Posted June 25, 2021 1 hour ago, Exige man said: Yes my chassis is a standard wide body? what Quinten means is that Westfield make/made a number of different chassis for different engine/gearbox combinations. The SEiGHT chassis has a special wider transmission tunnel area for the bigger V8 gearboxes to fit. It also had more reinforcement around the diff area to cope with the increased torque than standard chassis had, when it was first launched, though more modern chassis gained more reinforcement in that area too, over the gears, as power levels increased. What age chassis/car is it? Do you know which version you have, a Type 9 chassis, or an MT75 chassis? (Which you have will dictate how much of the tunnel area needs cutting out and re-fabricating.)
Dave Eastwood (Gadgetman) Posted June 25, 2021 Posted June 25, 2021 - Fun fact, when Westfield launched the SEiGHT it had so much more torque than any of the four cylinder options at the time, the factory was absolutely terrified of the potential liability issues with it, from a badly built version. So Kit’s we’re only supplied with rolling chassis, and the factory made the insurers aware of SEiGHT chassis numbers, to ensure that a converted stock chassis couldn’t be insured! That changed over the years, as four cylinder power plants got ever more powerful. But even at the end, I seem to remember the SEiGHT chassis still only came fully panelled, with all the fuel/brake lines fitted.
Rednop1 Posted June 25, 2021 Posted June 25, 2021 Seight chassis was made from a different gauge steel 2
Rory's Dad Posted June 25, 2021 Posted June 25, 2021 13 minutes ago, Rednop1 said: Seight chassis was made from a different gauge steel The most significant (unseen) difference. Of course, you can do what you want but I'd be very careful about the insurance implications. 1
Allan Cooke Posted June 25, 2021 Author Posted June 25, 2021 3 hours ago, Dave Eastwood (Gadgetman) - Club Secretary said: what Quinten means is that Westfield make/made a number of different chassis for different engine/gearbox combinations. The SEiGHT chassis has a special wider transmission tunnel area for the bigger V8 gearboxes to fit. It also had more reinforcement around the diff area to cope with the increased torque than standard chassis had, when it was first launched, though more modern chassis gained more reinforcement in that area too, over the gears, as power levels increased. What age chassis/car is it? Do you know which version you have, a Type 9 chassis, or an MT75 chassis? (Which you have will dictate how much of the tunnel area needs cutting out and re-fabricating.) My car is a 1993 with a type 9 gearbox
