Boney Posted June 5, 2021 Share Posted June 5, 2021 Hi had the car for 13 years and it has now come for someone else to enjoy the car, just had fresh MOT so ready to go detail as follows Built and registered by Terry Nightingale Sports Cars on 16/8/96. The car has been very successful at Curborough winning it’s class in the Curborough Championship in 2005. 2nd in 2004 and 3rd in 2003. price £11,950 ono Chrome yellow wide body work V8 bonnet Fluke carbon fibre Detachable rear arches Carbon mods carbon rear arch protectors Carbon mods carbon fibre half doors Carbon mods Carbon fibre CSR cycle wings RAC roll bar with rose jointed rear struts Front cross brace (rose jointed) SPA carbon fibre race mirrors with extended arms SPA carbon fibre centre mirror Westfield aeroscreen with smoked visor Carbon fibre Mickmade front splitter Westfield carbon effect rear light housings LED rear Lights including fog Mickmade carbon rear diffuser Mickmade carbon fibre front headlamps carbon fibre nose cone ENGINE Vauxhall 16V engine built in 2003 by Mike Kenny Race Engines. All QED components briefly comprising..... Coscast head 450 spec cams Acrolite pistons Standard early strong rods ARP big end bolts Crank shaft balanced and heat treated Flywheel lightened Modified oil pump to adjust pressure Adjustable vernier gears Group N racing valves Lighter valve springs Mechanical buckets QED direct to head throttle bodies running on DTA management system. Swirl pot fabricated into standard fuel tank. SBD Air scoop Carbon engine cover Rad tec alloy radiator and 10 inch fan (2015) Alloy header tank D1 alloy catch tank Wunoff bonnet exit manifold Techcraft megaflow repackable exhaust Rolling road tested at Northampton Motorsport producing 227BHP. 171 torque Prints available..... TRANSMISSION Type 9 BGH gearbox paddle clutch 3.92 LSD (SPC) SUSPENSION, WHEELS AND BRAKES Image split rims black 7 inch wide Toyo 205 888’s virtually brand new all Quick rack Front anti roll bar Rear anti roll bar Protech alloy shocks Corner weighted. Wide track Westfield alloy front uprights BRAKES Rear discs grooved Ultralite alloy hubs (front) Wilwood 4 pot Calipers Mintex M1144 Pads Wilwood Cross drilled and grooved front discs INTERIOR Sabelt 3 inch 4 point harness Removable MOMO 270mm steering wheel FIA cut off switch on dash SPA design kit dash 2 Bespoke gear lever extension by procomp Carbon fibre tunnel panels Carbon fibre rear panel Carbon fibre boot lid Fluke carbon fibre seats Carbon fibre side panels Shift light fitted Microtronics shift light Odyssey light weight battery fitted. set up by northampton motor sport Message for details or more pics. etc, throw in spares if goes for the right price body has a couple of grazes as it has been used but always been reliable as done lemans twice etc pictures taken 05/06/21 price £11,950 ono 3 Link to comment Share on other sites More sharing options...
Boney Posted June 19, 2021 Author Share Posted June 19, 2021 reduced price Link to comment Share on other sites More sharing options...
TAFKARM Posted June 19, 2021 Share Posted June 19, 2021 PM’d Link to comment Share on other sites More sharing options...
TAFKARM Posted June 19, 2021 Share Posted June 19, 2021 Ah, not PM’d as trial members can’t receive messages, I’m unable to contact you... Link to comment Share on other sites More sharing options...
Boney Posted June 19, 2021 Author Share Posted June 19, 2021 Hi PM sent Rush motorsport, my inbox was full Boney Link to comment Share on other sites More sharing options...
