Smudge62 Posted May 31, 2021 Posted May 31, 2021 What is the preferred height of the race numbers that is mostly used on Westfields, I had to use 11" on my rally car but that's far to big on such a small car and I know a smaller size would fit better but unsure how much smaller. Quote
Simon Waterfall Syman84 Posted May 31, 2021 Posted May 31, 2021 9inch or 11inch for msuk blue book spec. Quote
IanD Posted May 31, 2021 Posted May 31, 2021 I have always used 9" Though as long as they are clear they dont seem to be too fussy for speed events Quote
Maurici- CleaR Motorsport Posted June 1, 2021 Posted June 1, 2021 My Race plate is allways been A4 Size (the size of my cutter) and never had any problems as long as they are clear. However I've been excluded for less obvious things, so moving on, I would stick to Blue Book Regulations. 1 Quote
Mark (smokey mow) Posted June 1, 2021 Posted June 1, 2021 This is what the MSUK regulations say, but in reality providing its readable then I’ve not known them to be that strict on applying the rules. Quote
Terry Everall Posted June 1, 2021 Posted June 1, 2021 For hillclimbs and sprints it is not normally a requirement to comply with 4.1.2 as we dont fix a nosecone number. There are some places I have heard of that ask for it as an extra in their Supplementary event regs Quote
Andy - a15cro Posted June 1, 2021 Posted June 1, 2021 When or how do the numbers get allocated? Quote
Andy - a15cro Posted June 1, 2021 Posted June 1, 2021 21 minutes ago, cast iron said: for racing or sprinting? Sprinting, i.e the Blyton one coming up in July. Quote
Simon Waterfall Syman84 Posted June 1, 2021 Posted June 1, 2021 Andy you will get you number when the final instructions are sent out about 1-2 weeks before the event Quote
Andy - a15cro Posted June 1, 2021 Posted June 1, 2021 Thanks @Simon Waterfall Syman84 got my number board cut out and stuck on. Thanks @Hawkemotorsport for the couple of stickers with my last order. Just needing the rest of the pack to find a sticky home for Quote
cast iron Posted June 2, 2021 Posted June 2, 2021 sprinting, bit of electrical tape usually does Quote
stephenh Posted June 2, 2021 Posted June 2, 2021 On 01/06/2021 at 10:07, Terry Everall - WSCC Competition Secretary said: For hillclimbs and sprints it is not normally a requirement to comply with 4.1.2 as we dont fix a nosecone number. There are some places I have heard of that ask for it as an extra in their Supplementary event regs Notably Shelsley Walsh, where they require a number on the nose or bonnet of the car so the pre-start line marshall can see your number as you approach him. However the nose cone number can be smaller, as long as it is readable for 20 or 30 feet. I used black electrician's tape for that one, which they were happy with. Quote
Terry Everall Posted June 2, 2021 Posted June 2, 2021 Andy Your number will change at every event 1 Quote
