rev limiter to suit 4 cyl with old school coil
i removed this over winter as my current dizzy has its own limiter, its an accuspark one and was purchased about 5 years ago. works fine, although i have mislaid the back cover, which if required i could sort out , together with the now shortened tails that suited my application which i can lengthen if needed. was installed on a xflow.
will only work on old school single coil systems
not for use with multi coils or ecu's.
10 quid plus postage
it is this one https://www.ebay.co.uk/itm/AccuSpark-Rev-Limiter-for-Traditional-Ignition-Systems-4-6-8-Cylinder-Engines/174156689973
Hi, as per the msg's I'll take this consider it sold👍
Ian
On the off chance Ian doesn't take this, I will :)
Many thanks,
Brads
Ian
