woodman Posted May 6, 2021 Posted May 6, 2021 (edited) I can offer my 1990 narrow sprint car chassis with Ali floor and side panelling + the all important V5 . I have owned this chassis for over 17 years and it is a genuine 'championship winning chassis'. The tunnel mouth has been widened to accept most engine/gearbox combinations. also inc Set of four rear wishbones for above chassis with poly bushed inners joints and also inc rose joints A pair of rear uprights with hubs A pair of driveshafts with H/D tubes An upper and lower doner steering column Quick rack Ali , foam filled , 10L fuel tank Race seat with bracket A RAC type rollhoop ( needs rear stays) Comes with a set of modern , detachable arch type bodywork , Carbon dash and rear panel Bodywork pics were taken when car was complete £2950 for the lot I may have some other bits to throw in , eg 3 front wishbones, light bracket etc Edited July 23, 2021 by woodman revised
ci_newman Posted May 7, 2021 Posted May 7, 2021 Where are you located, interested in the bodywork if it's a highline nose / bonnet?
John Loudon - Sponsorship Liaison Posted May 7, 2021 Posted May 7, 2021 That car won the Speed Series not so long back 2
Beggers Posted May 8, 2021 Posted May 8, 2021 12 hours ago, woodman said: bodywork photos added I’ll take body work! Pm coming
Martin Letts - Joint Hampshire & IOW AO Posted May 9, 2021 Posted May 9, 2021 I’m in for rear disc brake conversion, as discussed.
John Dolan - Wirral & North Wales AO Posted May 10, 2021 Posted May 10, 2021 Do you have a standard roll hoop?
John Dolan - Wirral & North Wales AO Posted May 10, 2021 Posted May 10, 2021 1 hour ago, woodman said: Yes John. It is black Could you post a pic please.
