Pinto / Cosworth engine parts - garage clear-out.
Following the sale and breaking of the sprint car I have the following engine parts taken from a 205 Pinto / Cosworth block. The engine didn't explode (despite my best efforts) so these parts have not seen any swarf running around them. And yes some of them could do with a clean and a coat of black paint.
1. Pinto / Cosworth distributor shaft and pulley - £25 + P&P
2. Pinto / Cosworth distributor shaft oil seal and cover. Oil seal may need replacing - £10 + P&P
3. Pinto / Cosworth lower timing belt guide / oil seal / cover - £15 + P&P
4. Cosworth (may fit Pinto) triple belt crank pulley with 36 - 1 toothed wheel fitted. NOTE - the bolts for the toothed wheel render the rear most V belt section unusable. However this could be fixed with judicious application of a better way to secure the toothed wheel... OR the toothed wheel can be removed - £30 + P&P
5. Cosworth crank timing belt pulley - £15 + P&P
6. Cosworth / Pinto twin belt water pump pulley - £15 + P&P
  • 2 weeks later...
BTTT
  • 9 months later...
BTTT 'cos I still have all these bits clutering up my hall!
