Blatman Posted April 27, 2021 Posted April 27, 2021 Following the breaking and sale of my sprint car I have the following "left over"!!! 1 x Aluminium bellhousing for a Type 9 gearbox. It's from a Morgan... I never fitted it so it's in the same condition in which I bought it. NOTE... It's 150mm face-to-face depth which is right for the short input shaft type 9. £100 + P&P *Now includes a hydraulic clutch slave cylinder. SOLD Second, there is a steel "skeleton" flywheel with Pinto ring gear. This weighs in at around 3Kg's and when attached to the Cossie meant it revved like a bike engine, only better This will fit a Pinto or a Cossie and was one of the best mods I ever did. I put about 50 miles on this before I stopped sprinting and as I was in the road going class it didn't hasn't endured any abuse at all! £120 + P&P SOLD Finally there is a matching twin plate clutch WITHOUT friction plates. This is from Superclutch as can be seen. Again, about 50 miles and a decade or so of storage is all the action this has seen. Yes the surfaces of the intermediate plates could do with a good clean but apart from that it is in full working order. The closest thing I can find to this is from Quartermaster and they're over 500 quid, so £200 + P&P 1
Blatman Posted April 27, 2021 Author Posted April 27, 2021 29 minutes ago, Rush Motorsport said: That flywheel looks lovely! And for a century-and-a-half all that loveliness can be yours... 😄 2
Blatman Posted February 17, 2022 Author Posted February 17, 2022 Back to the top as I still have these and I am keen to shift them. I have updated the openining post with price reductions and provenance info. Additionally I have an hydraulic clutch slave cylinder for the bellhousing/clutch that will be familiar to many of you. I'll throw it in with the bellhousing because it will likely need a seal kit throwing in.
Tuner58 Posted February 17, 2022 Posted February 17, 2022 I`ll take the bellhousing if you can work out P&P
Blatman Posted February 17, 2022 Author Posted February 17, 2022 4 hours ago, Tuner58 said: I`ll take the bellhousing if you can work out P&P Where in the UK are you? I could spend quite a lot of time with bubble wrap and a box that I would rather spend having a drive somewhere
Tuner58 Posted February 17, 2022 Posted February 17, 2022 6 minutes ago, Blatman said: Where in the UK are you? I could spend quite a lot of time with bubble wrap and a box that I would rather spend having a drive somewhere PM sent
Blatman Posted March 6, 2022 Author Posted March 6, 2022 BTTT - just the 7.5" clutch cover and non-friction plates left to go.
