Hello!
The time has sadly come, with much regret, to sell my C20LET Westfield. I have always been a classic mini lover from when I was 16 years old, but sold my Mini Clubman Estate that I did a front engine Honda engine conversion on, to purchase this Westfield 5 years ago. I have now; however, found myself a potentially dream mini (which I have already purchased) that is a rear engined Honda K20 Z Cars Mini… I do hope that this will be as fun as the Westfield has been, but I can’t afford to keep both unfortunately!
I have owned this Westfield SE Wide body since March 2016 and have spent a fair bit of money on it since then, for the most part fixing it up mechanically, as it had been neglected a bit and wasn’t in the best state, but have also made a few improvements too.
Mileage is 8948
Has just been MOT'd (March)
The spec is as followed:
Engine
Vauxhall C20LET (Calibra Turbo engine)
Fully rebuilt in by Headshop UK in September 2016
SC Typhoon standalone ECU
Mapped by EFI Parts – 288 bhp & 280 ft lbs of torque
Turbo Smart Boost Controller
C20XE Cam Shafts
Forged Rods and Pistons
VXR Injectors
K16/26 hybrid turbo (KRS Turbos) - built September 2018
SBD dry sump kit
Setrab Oil Cooler
Custom made exhaust by JP Exhausts
Drive chain
Sierra Cosworth T5 Gearbox  - rebuilt by A.P.F Gears August 2018
Sierra Cosworth rear LSD diff
Heavy Duty Clutch Cover
Cerametallic Paddle Clutch Plate – new in 2019
O.Z. Racing Wheels
Body
Caged roll cage
Carbon flared side panels (original side panels cut out to improve cooling)
Fiberglass seats (some cracks in them)
Most of the interior is custom made Carbon Fibre
Battery mounted in passenger footwell
Stack Dash
Zeitronix Wideband Lambda sensor and gauge
Peddle box from a Formula 1 Tyrell driven by Martin Brundall (sounds cool if nothing else?)
Suspension/Steering
Titan custom steering rack – rebuilt by them in 2017
Corner weighted and tracked by Clear Motorsport (75KG in drivers seat)
Weighs 600KG without a driver
Brakes
Comp B16 Front Brakes
This car was built by a guy on this forum to race in the sprint series back in 2002; I have paperwork going back to 2003 for it, including an old MSA log book from 2006 (some old videos on Youtube). Body work wise, this Westfield is not in showroom condition, as it has been owned to be driven and does have the odd bit of minor damage to the fiberglass. I have also not taken it on track since I have owned it (MASSIVE regret that I am able to say this, but not worth the risk of me taking it now ☹).
Bad points are that it does leak oil when sat for periods of time. The oil doesn’t go down at any great speed, so I do believe that it primarily leaks when it is just sat. It leaks from two places, the bottom off the oil tank due to the thread being damaged and there’s a slow drip from the pressure relief valve on the external oil pump (this seems to be a common thing). Due to the undertray on the car, this can make a bit of a mess on the base of the tray and where ever it is sat!
The rev counter does not work on the dash (this has always been the case, but never bothered me enough to fix it!). The ECU does read the RPM, so will either be a wiring issue or a faulty dash unit.
A bearing in the left side of the brake peddle has some play in it.
There are a couple of bits of Fibre Glass on the body work that have smalls cracks and the Fibre Glass seats have a couple of cracks in them both.
Hard to price such a car, but looking for £10,000.
Serious buyers only please, no test pilots.
I am sure that I will have forgotten bits, but any questions, please message on here or WhatsApp/text me on 07742109509.
I am located in South Manchester.
Cheers,
James
IMG_20210410_155053.thumb.jpg.bb647019fd3dba6caefb1f165cff1a69.jpgIMG_20210410_154646.jpg
IMG_20210410_154659.thumb.jpg.4dd15f9e3440b19c2fdba4bcb77a6e67.jpgIMG_20210410_155009.jpg
  • Like 3
I think we can work out who built this originally... bargain alert!
  • Like 3
Yep probably one of the best built Westfields in the UK, back in its day (not much to touch it now either). The first car engined car I recall being under 500kgs wet. that was with the c20xe.
Thanks Paul.
Also a Sequential box back then, which unfortunately is not in it any more. Was removed before my ownership
  • Hepple changed the title to SOLD ☹️ - Westfield SEiW 2002 - C20LET
