SE bonnet, pedal box cover
Hi all.
I'm in the process of reserecting an 88 SE and in desperate need of a bonnet pedal box cover brake master cylinder with reservoir and headlights.
Also for a 1.6 crossflow carbs and manifold. Currently its running a single down draught.
Anything considered.
Jon
Is this a narrow body
Chris
Chris
Hi Chris.
Yes it is narrow.
Jon
I used ‘past parts’ to sleeve and recondition my master cylinder.. about £170 if it’s salvageable. I assume it’s a mk3 cortina one ?
The reservoirs are like hens teeth!.. they also almost every time they are removed snap the front ‘barb’ fitting off!
I gave up on them a long time ago and made a stainless reservoir..
the pedal box cover is probably repairable with some glass Matting?
How fast do you need the pedal cover I have a mould for one if you want it. I also have one that you can have as soon as I can go and get it.
thanks for the responses, pedal cover sorted.
Bonnet desperate for. Anything considered.
Chris
Hi Chris.
Yes it is narrow.
Jon
Bump,
Bonnet still required
Master cylinder and reservoir still required
