Joe90 Posted March 29, 2021 Posted March 29, 2021 Hi all, Over the next few weeks I'll be looking for a new set of seats and harnesses - interior carpet - preferably a full set and also a pair of full doors. If you have anything available or something you'll be taking out over the next few weeks let me know. Looking for black seats and carpets and red or black harnesses preferably as the car is red but if you have anything you think would suit then try me Cheers, Joe.
Dave Eastwood (Gadgetman) Posted March 30, 2021 Posted March 30, 2021 You’ll need to work out which carpet set you need, as there are a number of different versions, caused by different types of Westfield chassis having different width tunnels to accommodate the various gearboxes used. The extra width in the tunnel, is achieved by making first the passengers side of the car narrower, and then in the widest tunnel cars, making the drivers side slightly narrower, too. If it’s a car with a chassis supplied after the early 2000’s then for Zetec/Duratec/XE engined cars, the MT75 tunnel is most common. This is a wider tunnel than on earlier cars with Type 9 tunnels. But note, there are many MT75 tunnel cars, with Type 9 gearboxes fitted! What engine and gearbox do you have, and is the drivers side of the car, and footwell wider, or the same width as the passengers side?
Westfield Chesil Limited Posted March 30, 2021 Posted March 30, 2021 We have a set of black / black in stock Sport Turbo seats. All other items made to order.
TAFKARM Posted March 30, 2021 Posted March 30, 2021 Take it out in a downpour first...you’ll decide to remove the carpets! 1
Kingster Posted March 30, 2021 Posted March 30, 2021 27 minutes ago, Rush Motorsport said: Take it out in a downpour first...you’ll decide to remove the carpets! What he said 1
Joe90 Posted March 31, 2021 Author Posted March 31, 2021 On 30/03/2021 at 10:56, Westfield Parts Dept said: We have a set of black / black in stock Sport Turbo seats. All other items made to order. How much are you after for the seats? Can you message me with some pictures? Cheers.
Joe90 Posted March 31, 2021 Author Posted March 31, 2021 On 30/03/2021 at 12:26, Rush Motorsport said: Take it out in a downpour first...you’ll decide to remove the carpets! I'm planning on being a fair weather driver
Joe90 Posted March 31, 2021 Author Posted March 31, 2021 On 30/03/2021 at 01:06, Dave Eastwood (Gadgetman) - Club Secretary said: You’ll need to work out which carpet set you need, as there are a number of different versions, caused by different types of Westfield chassis having different width tunnels to accommodate the various gearboxes used. The extra width in the tunnel, is achieved by making first the passengers side of the car narrower, and then in the widest tunnel cars, making the drivers side slightly narrower, too. If it’s a car with a chassis supplied after the early 2000’s then for Zetec/Duratec/XE engined cars, the MT75 tunnel is most common. This is a wider tunnel than on earlier cars with Type 9 tunnels. But note, there are many MT75 tunnel cars, with Type 9 gearboxes fitted! What engine and gearbox do you have, and is the drivers side of the car, and footwell wider, or the same width as the passengers side? Hi Dave, I've measured across the tunnel as per the westfiekd website and have around 16cm which leads me to believe I have the type 9 tunnel. I've found a set for £75 (Tunnel, back section, under seat carpet, front carpet) I've messaged the bloke with my measurements and they seem to fit Is there anything else I need to watch out for? Cheers, Joe
Wowblaauw Posted March 31, 2021 Posted March 31, 2021 I have a set of yellow 2 1/2” trs belts in really good condition. I also have a set of 3” trs in green which have the quick release buckle. I also have a very used set of sabelt in black 2 2/12” belts. Take your pick, let me know and I’ll send images. Cheers Craig
Joe90 Posted April 5, 2021 Author Posted April 5, 2021 On 31/03/2021 at 23:08, Wowblaauw said: I have a set of yellow 2 1/2” trs belts in really good condition. I also have a set of 3” trs in green which have the quick release buckle. I also have a very used set of sabelt in black 2 2/12” belts. Take your pick, let me know and I’ll send images. Cheers Craig Cheers Craig. The cars red so couldn't go yellow as I'd look like a McDonald's Looking for a newish red or black set ideally. Thanks 2
Wowblaauw Posted April 5, 2021 Posted April 5, 2021 Let me have your email address and I’ll email some pics of the sabelts
