Steering column complete
Don’t mind something that needs a bit of a tidy up. 🙂
ok now worked out I need both parts of the column.
From memory they are mk2 Escort
I think it may as easy if you just came round and see what bits I have 😆
 I have one also, need to see what I may nicked off it over the years and yes MK2 Escort. My one has been modified by WF as it has the cycle wing restriction in them which limits lock., if you get one from an Escort you would need to add these or your cycle wings will hit the bodywork. I'll take some pics tomorrow for you.
  • Haha 1
  • Beggers changed the title to Steering column suitable for Narrow chassis
I’m such a doughnut!!! I meant column but wrote rack 😂😂 def the column I need!
I think I have the upper column allegro style? So its the lower but that joins that to the rack or I’ll take a whole set of another column if its all there.
edit - need a whole column really.
Ahh, I don't have one of those. If no one replies check out Car Builder Solutions website , they do various shafts and joints etc.
Download the catalogue here and look at pages 37 to 39.
https://www.carbuilder.com/CatalogueRequest
Have you considered fitting a later upper column. Weld the tabs on then bolt on. I have the original type fitted to my SE but I do not know if the IVA testers will accept it. Also for test I now have a IVA compliant steering wheel hub with a modern WF IVA steering wheel. You are  welcome to view my set up (Covid safety observed)  as I have an Allegro column in stock just in case I have a problem with IVA. I plan to final fit scuttle in the coming weeks.
  • Beggers changed the title to Steering column lower part
Sure i have one
  • Beggers changed the title to Steering column lower complete
  • 2 weeks later...
Still looking, will take a complete column as my upper isn’t great.
  • Beggers changed the title to Steering column complete
I have a column with a quick release on, I can get some pics tomorrow if your interested
  • Sad 1
  • 2 weeks later...
Hi, still looking. Must be complete 🙂
  • 2 weeks later...
Final bump looking for complete (from rack to steering wheel, every piece) steering column before I go Westfield and buy new. 🤑😬
