jph Posted February 13, 2021 Posted February 13, 2021 (edited) Hello guys, I'm french, 43 years old married and 5 children. I bought 2 month ago a WESTFIELD seven pre-lit of 1987. Because of the weather, I drove not a lot up to now but I have noted that my tyres are too old (GOODYEAR NCT70 with DOT code "059"). So I would like to change it but I'm not sure how to get up the car and where position the jack. Can you help me saying or showing me with pictures how to make ? In terms of new tyres, I saw Uniroyal RainExpert 3 because of the price. If you have a better proposal, I'm open. Thanks by advance for your help. Edited February 13, 2021 by jph 2 Quote
CraigHew Posted February 13, 2021 Posted February 13, 2021 Hi JPH. Do a search for "jacking points" including the quotes ("") and you will find what you're looking for. I use Toyo R1R tyres on my 15 inch wheels as I prefer the semi-slick treads Here's where I jack mine from, ok to use diff at rear; Quote
Stuart Posted February 13, 2021 Posted February 13, 2021 Bonjour JPH. Michelin PS3 or Uniroyal Rainsport get good reports Quote
jph Posted February 13, 2021 Author Posted February 13, 2021 thanks a lot CraigHew. You're absolutely right, I just found a topic about jacking points with explanation and pictures. I assume that I have to lift up front in first because handbrake or gear just block rear wheels. Stuart, in my syze, 185/70R13, I do not find MICHELIN PS3. The other solution would be the R888 semi slick in 185/60/13 but more expensive and the car will be lower. As I think I will make only road, I'm not sure it's the best solution. Quote
Kingster Posted February 13, 2021 Posted February 13, 2021 8 minutes ago, jph said: 185/70R13 I think you can get the rain experts in that size - correct @AdamR? oh - and welcome! Quote
AdamR Posted February 13, 2021 Posted February 13, 2021 Welcome jph! Yes, I am pretty sure they come in that size. Any good quality road tyre should work nicely. Quote
